Old May 8, 2009, 08:36 AM
JD JD is offline
Originally Posted by The MAX View Post
is != supposed to be a "not equal" sign?
That's what it means.
Sure RAID isn't the most ideal backup, but it still helps IMO.
Old May 8, 2009, 08:56 AM
dataxpert's Avatar
Raid 1 make it more friendlily for recover of a mechanical failure, just replace the drive and voila..... But it’s not a back-up….. Honestly I see more often HD failure, than other thing ….. so raid1 is a good thing to have, combine with an external HD.
Personally I use raid 1 ( if not 5) in all my computer I have important stuff , and I have scheduled backup, in my Ubuntu backup server, in my garage… so if the house pass on fire….. When I download software than I pay, I also burn it on a DVD.
Old May 8, 2009, 12:57 PM
HDDs (in my experience) don't tend to go as often as cheap RAID solutions.
RAID1 will protect you all day long from a drive dying, but how about your controller deciding to blow it's brains out? What then?
Trust me. I've had it happen a few times.
And yes, != means does not equal
Old May 8, 2009, 01:35 PM
LionRed's Avatar
IF a drive dies in a raid 1...or controller. Can't you take a drive hook it up as a normal stand alone drive...windows will say this drives needs a scandisk. Fix whatever...and the drive is viewable in windows?
I swear this happened in a RAID10 and I was pleasantly surprised to get my data back.
They say you can tell how rich a man's life has been, by how many dogs he has had in it.
RIP Kiwi - Oct 19th/05 - April 18th/11, you will always be our puppy!
Old May 8, 2009, 01:44 PM
dataxpert's Avatar
In the situation of the OP, it"s the motherboard that will died.... no problem for the drive all the data still their. Since I always install the OS in a diferent drive, it"s not a big, deal, change the mtb inform the raid bios about the drive , reinstall windows, an it's done.. in the case of the OP, he change the board and reinstall windows, or adjust the drivers ( if he can't find the same board ,)
Old May 8, 2009, 01:52 PM
LionRed's Avatar
I've swapped a couple MB's with raid's (in the past few months)and they didn't complain about it. From what I understand...it is becoming less of an issue with newer MB chip sets being backwards compatible with older Intel Raid chip sets. This was even going from a 2yr old Asus to a current Giga-Byte MB.
But as is the case with computers.....something always pops up.
Old May 8, 2009, 02:30 PM
dataxpert's Avatar
that's it data in raid 1 are not safe from operator mistake and virus, but they are ( at some extend ) from HD failure. I said I reinstall the OS, someone can of course just swap the MTB and just adjust for the drivers. A raid disk is a raid disk, the controler don't need to be compatible.....
I don't know why some people are allergic to Raid 1 ( it's means 2 disk in miror with the same data, we are not talking about raid 0 ) ... may be it does not make the computer more safe in every situation, but it does not make it worst.. no if someone can not retrieve data from a controller failure, he just have to call someone who know…. Or ask here…
drives for raid, question Jim Storage 4 January 30, 2009 08:54 AM
RAID Question Wein13 Storage 7 October 12, 2008 06:15 AM
RAID question miggs78 Storage 17 August 30, 2008 03:12 AM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
raid controller question.... rob123 Storage 2 November 13, 2007 01:14 AM
