Old May 4, 2009, 06:05 PM
Default Vista Compatible Partitioners Help!
Hi I have vista home premium x64. Im thinking of partitioning my drive but dont know what compatible program to use that wont destroy my data in the drive while partitioning. I've used the built in windows disk management but it has limited functions.
Any help will be appreciated thanks
Old May 4, 2009, 06:11 PM
Dwayne's Avatar
The disk management in Vista actually works very well for shrinking and expanding the partitions. It has been a while, but is there a new version of Partition Magic out there? I am sure a quick Google search will find something similar.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old May 4, 2009, 06:19 PM
JD JD is offline
Acronis Disk Director works for me in Vista x64, even though it's a rather old program.
What aftermarket coolers are compatible with 8x00series? AERo Water Cooling 5 December 18, 2007 01:26 PM
Striker Extreme/ compatible memory? wpurcell CPU's and Motherboards 2 August 23, 2007 01:41 AM
Will my mobo be compatible? Shiverwarp RAM 1 July 19, 2007 04:14 AM
Great image resizing utility that's compatible with XP and Vista Misoprostol O/S's, Drivers & General Software 4 April 24, 2007 07:28 PM
Help! old floppy compatible??? Babrbarossa CPU's and Motherboards 7 December 17, 2006 12:58 AM
