Old April 14, 2009, 05:47 PM
Default not seeing hdd in my computers.
today i got my 1TB WD Black from ncix, plugged in , detects in bios, but nothing in "my computer"...cant see it?
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old April 14, 2009, 05:51 PM
Dwayne's Avatar
If you are using Vista you have to open up the Admin tools. Click start - control panel - system and maintenance - Admin tools
then select computer management
Find Storage and Disk Management and you disk should show up there... that is where you partition it and format it.
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
Old April 14, 2009, 05:53 PM
Infiniti's Avatar
I'm pretty sure that new hard drives come unformatted. You'll need to go into Disk Management and it should show a bit that says Unpartitioned space or something like that. Right click on it and select format.
Old April 14, 2009, 05:56 PM
do i want MBR or GPT?
Old April 14, 2009, 06:00 PM
MBR.
GPT is only needed if you ever planned to boot.
Dwayne's Avatar
Try GUID Partition Table - Wikipedia, the free encyclopedia for info
I am not positive but GPT looks like the choice but I would read a bit more to make sure.
Another link
Using GPT Drives
Old April 14, 2009, 06:03 PM
gingerbee's Avatar
second that
Old April 14, 2009, 06:12 PM
Another link
Using GPT Drives
The problem with GPT tables is only a select few OSs can actually properly use them so migrating a hdd with a GPT table to a older OS maybe a lot more difficult.
MBR is still preferred unless you plan to boot with a 2tb drive which makes 0 sense to me.
2tb drives are for storage not booting.
Old April 14, 2009, 06:14 PM
Dwayne's Avatar
I agree, but if he is running Vista (especially the 64 bit version) with no plan to go back, and the 1 TB is storage, then it sounds like GPT is more efficient. Like I did say, some research is in order to make the decision... never hasty, always think it out I guess.
Old April 14, 2009, 06:16 PM
And I'm saying that GPT is only needed if you plan to boot 2tb or larger volume drives. I have researched this and its the only main difference between MBR and GPT tables.
And who in their right mind uses a 2tb drive for a OS drive? That is super silly.
3 PSU's 3 Computers but what one for each. mailaw Power Supplies 4 March 28, 2009 12:19 PM
2 computers, one monitor....... rob123 Display Units 12 December 31, 2008 05:58 PM
Computers Can't See Each Other Even if in Same Workgroup geokilla Networking 0 October 4, 2008 12:52 PM
Hardcore computers Wankerfx Off Topic 6 March 31, 2008 07:29 AM
lu computers... Rausch Off Topic 3 January 28, 2008 04:30 PM
