Old April 2, 2009, 01:35 PM
AERo's Avatar
Default My Raptor temps are quite high... will this kill it?
My WD Raptor 160GB temps are reaching around 60C degrees!
(according to HWmonitor)
Is this a danger to its health?
Temperature is reaching 60C degree when I run HDD benchmarks
and when I format the littl' sucker.
Idles around 55C degrees
AMD64 Phenom X4 940 @ 3.6GHz G.Skill Black π 2x2GB
Asus M3A78-EM
Powercolor 4870x2
OCZ Vertex 120GB, Kingston V 128GB, Raptor X,
Antec Mini P180 CM UCP 700W
Samsung 240T, 226BW
Logitech G15, Microsoft X8
Watercooled by:
Swiftech Storm Rev.2 , 4870x2 FCB
1xMCP350 w/Petrastops , MCR220 QP , MCRES-MICRO , Tygon 1/2" ID
2 x Scythe Kama Ultra 1000
Old April 2, 2009, 04:31 PM
gingerbee's Avatar
i am not to sure what there op temp is but my 750,640 or even my 1T dont go over 50 ever in a case out of a case no air flow ( that said they dont make a raptor 160 gig ) ya i got it typo read signature my 74 raptor temp right now is 32c room 22c so these vraptors might run hotter if that helps any
Old April 2, 2009, 08:28 PM
WD1600ADFS
Newegg.com - Western Digital Raptor WD1600ADFS 160GB 10000 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - Internal Hard Drives
This Raptor is in the top 5.25" drive bay of my Mini P180, which gets
almost no airflow.
Never seems to get temps below 55C and above 60C, no matter the environment...
(open air, with 2x30mm fans blowing on it, in a silencer box, etc.)
AMD FX-60 @ 3.2GHz w/ Storm rev.2
DFi CFX-3200DR/G
4 x 1GB Corsair TWIN XMS 3500LL
ATi x1950 Pro CF w/ EK FC1950
Western Digital Raptor X, Raptor 150, 1TB
2 x Seagate
7200.11 500GB
Creative X-Fi Elite Pro
Pioneer 212D
Seasonic M12 600W
CM Stacker 830
MCR220 QP, Thermochill 120.1
Akasa&Scythe 120mm s
2xMCP350, Micro RES, Sunbeam Theta
Old April 2, 2009, 08:47 PM
gingerbee's Avatar
holly sh*t sorry about that there mate i don't like high temps so on anything
Old April 2, 2009, 09:46 PM
MpG's Avatar
MpG MpG is offline
Actually, I suspect the Egg's listing is in error. WD doesn't even list a 160GB drive on their website.
@OP: You might want to consider how the drive is mounted and what kind of airflow its getting. Personally, 50 degrees is my own limit, and I much prefer around 40 degrees. The original raptors are definitely hotter than most desktop drives (VR's are actually much improved in this department), but I think they're maximum rated temp by WD is 55 degrees.
Temps seem a little high... element291 Air Cooling 28 January 15, 2009 09:33 PM
4870 Temps too High? arekieh Video Cards 10 November 28, 2008 08:41 PM
High Temps BALISTX Overclocking, Tweaking and Benchmarking 20 July 14, 2008 04:32 PM
HDD, CPU temps too high? donimo HTPC Systems & Software 12 June 6, 2008 09:34 AM
What are high temps for the 9800GTX?? bushwickbill Video Cards 0 April 29, 2008 06:57 AM
