Old March 31, 2009, 03:00 AM
somecanadianguy's Avatar
I see a lot of people on other sites recommending using 3 partitions...
One for bootfiles and page file, one for windows, and one for data.
How does that sound?
Is that pretty simple to do?
Old March 31, 2009, 04:22 AM
3 of 7's Avatar
Just go with 2, one for OS and "core" programs like av, office etc and put everything else ( including your docs ) on the larger one.. When you install programs just change the C: to a D: and leave the rest of the string as it is.
Old March 31, 2009, 04:50 AM
What about 3d programs and stuff like that?... "work" stuff...
Is there any benefit to putting that type of stuff on a seperate partiton?
They tend to make things pretty messy and fragmented.
Old March 31, 2009, 04:53 AM
3 of 7's Avatar
I'm not a big fan of more than 2 partitions, too hard to keep track of everything and you'll wind up with one partition that's right full and other ones that have a ton of space left in em. Stick to 2 and defrag from time to time.
Old March 31, 2009, 05:57 AM
I understand most of what you're saying, and I'm certainly not trying to argue.
I'm just trying to decide what's going to be best for me.
2 will probably work just fine... even 1 would really.
How do you normally decide what programs to install on which partition?
If you're going to install any on the one with the OS... why not just install all there?
If I'm going to put PSP, Blender, and all my other work stuff seperate from my OS, I may as well just keep them seperate and make a 3rd partition.
Old March 31, 2009, 06:04 AM
3 of 7's Avatar
If you install all your programs on the same partition as the OS it will be too large to back up. I put small progs that update like java,flash antivirus etc on the OS partition.
Anything large (games etc) go on the second partition. You could certainly make a 3rd one for work programs, but I see no advantage over a work folder.
Old March 31, 2009, 06:24 AM
Thanks for the input.
I'll likely go with 2, but maybe 3...
If I mess something up I'll just try again.
Another question about the HD...
Is it necessary to sit through a full format? Or is quick format ok?
I don't know how long a full format of this drive would take, but I'm guessing more than a few minutes.
Old March 31, 2009, 06:49 AM
3 of 7's Avatar
I like to do a full format the first time around I've read that it's a good idea because it'll mark bad sectors ( If there are any) and you get the desirable sector size.. I may be working on outdated ideas here and I'd also like to hear the other guys opinions on this.
  #19 (permalink)
Old April 1, 2009, 08:17 AM
I'm still wondering about the quick format vs. full format.
I see a lot of people recommending just a quick one, and saying that a full is not worth the time. I will probably do a full format just to be safe, but is it really worth it?
  #20 (permalink)
Old April 1, 2009, 08:23 AM
3 of 7's Avatar
Sata drives format fairly quickly on a modern machine. I do a full one first time around and just go have a cup of coffee.
Tags
640gb , hard drive , partition
WD 640GB vs Samsung 640GB? JD Storage 23 December 6, 2008 04:21 AM
WD SE16 640GB vs. Seagate 7200.11 640GB -- A somewhat complete analysis. S_G Storage 60 October 22, 2008 07:49 PM
deleting a partition cmac79 Guides & How-to's 7 August 2, 2008 05:30 AM
Fat Partition to NTFS Boot Partition PaxeSalute O/S's, Drivers & General Software 1 May 2, 2008 01:28 PM
Partition problem... omgwtf O/S's, Drivers & General Software 1 July 13, 2007 12:55 PM
