Old March 27, 2009, 03:09 PM
Default Raid or ssd for 150$ (average)
Hi!
I have read on the topic, but I still come to a wall.
I would like to install an OS (windows) on a small drive. So I will have a fast loading one.
What would you like to suggest for around 150$ (can)?
2 cheap drive one raid?
or a ssd drive like the patriot 32g one?
it seem that it is a reliability vs performance battle.
Do I am wrong?
Thx!
Old March 27, 2009, 03:12 PM
CMetaphor's Avatar
Quadfather
Raid. Always.
everyone will always say though "If you loose one disk from a Raid 0, then you loose everything". Its true.... but then again, you'll still have a working drive leftover you can reinstall the OS on while you wait for the other one to come back from RMA. If a single disk v-raptor or SSD or whatever crashes.... you twiddle your thumbs for days while it gets RMA'd and you have No Computer at all. Just my $0.02.
Old March 27, 2009, 03:18 PM
CMetaphor's Avatar
Quadfather
PS:
Just as an extra little note. Raid 0 failure isnt as common as you might think. In my entire life I've had 1 Raid 0 array crash on me. And even then, there were "array health" warnings beforehand that allowed me to backup everything before one of the disks died. One Raid crash, and I've been using them for years and years and my OS/Games drive.
Old March 27, 2009, 03:37 PM
gingerbee's Avatar
stay cheap yes raid best bang for buck
Old March 28, 2009, 08:36 AM
Default re
Will there be a big difference between sata & sata2?
Worth it?
Old March 28, 2009, 08:45 AM
CMetaphor's Avatar
Quadfather
Everything is sata2 nowadays anyways
Old March 28, 2009, 09:00 AM
Default re
Alright so 2Xwd balck 640 would be great?
or 2 samsung f1 500g?
I'm not a space freak...
suggest?
Old March 28, 2009, 09:02 AM
CMetaphor's Avatar
Quadfather
WD Black 640g hands down.
Old March 28, 2009, 10:20 AM
Jake_HT's Avatar
WD Caviar black 640GB OR if you wanna save some money and don't need a 1.2TB RAID 0 lol, get 2x WD Caviar Blue 320GB, they are single platter (same size platter as the blacks, only less cache) and will provide similar results.
Here's what to expect from 2x 320GB blue drives in RAID 0... Best value by far. Got mine for 65 bucks a peice.
http://jakeht.deviantart.com/
Old March 28, 2009, 02:56 PM
Default re
I found caviar se 320g
but no Caviar ''blue''...
too old?
Help on Raid set-up Malam Storage 4 December 9, 2008 02:13 AM
Is this an average OC for a 9800GTX+ SC? Gameplaywarrior Overclocking, Tweaking and Benchmarking 5 October 16, 2008 03:53 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
raid help Jhayman Troubleshooting 9 November 8, 2007 02:10 PM
Sony 40" LCD TV KDL40S3000 - First Impressions from an average user Jamz Display Units 4 November 6, 2007 10:53 AM
