Recomendations....
I have a friend who is using a stardom HDD enclosure, its a 2 bay enclosure that fits right into the 5.25" bays in the case and gives you the option to hotswap your HDD is currently in a mirrored raid setup. He is hopeing to be able to use the system as is then at the end of the day take out one drive and remove it from the office... so if there is a fire or anything he will have a backup. the only problem is that everytime he puts the HDD back in the RAID has to rebuild which takes almost 2 hours. and he dosen't have the time to do this everyday. Does anyone else have a better solution for this? I haven't had much experience with raid or hot swappable HDD's
__________________ IM THE DUDE, PLAYING A DUDE, DISGUISED AS ANOTHER DUDE. |
