<~----> Short Stroking and RAID Questions - Page 2 - Hardware Canucks
Old March 22, 2009, 01:08 PM
Toronto122's Avatar
is there any negative to leaving it unallocated?
NZXT Rogue Cube Case
Intel i7 920 @ 3.8 w/Scythe Mugen 2
6 gb Patriot Viper 1600mhz low latency
Asus Rampage II GENE Motherboard
2 x Asus GTX 285 in SLI (710/1617/2700)
1 x 1tb WD Black
3 x WD 640AAKS in RAID 0
Enermax 85-1050 PSU
HP 30" 2560x1600, G19, G7, M-Audio Q40 Headset
Old March 22, 2009, 01:10 PM
Realityshift's Avatar
You cant use the space?
The Builders Hammer
Old March 22, 2009, 01:19 PM
Perineum's Avatar
Alright, interesting to hear another viewpoint on this. To be honest I've only done 2 installs of Vista and hadn't noticed anything (or never thought about it) regarding short stroking. I just decided to RAID 5 instead.
One thing I noticed is that on the Seagate Barracuda SATA drives it comes stock with a jumper on it that limits it to a compatibility mode. According to HD Tach my thruput almost doubled on my RAID after removing these jumpers from all my drives.
Results from "Long Bench" on my system after pulling the jumpers...
Old March 22, 2009, 01:21 PM
You can short stroke a raid 5 to gain more performance...
The Builders Hammer
Old March 22, 2009, 01:26 PM
Like it was already pointed out, your windows install and vital programs would be running on the first 100gb portion of your benchmark. Performance is dependant on how organized you keep your hard drives, if you have stuff all over the place and some of your important software gets put to the inner edge of the platters your going to see horible performance vs the outer edge. as for installing vista, its in the tools section when your formating your drive, theres a few usefull tools in there.
The Builders Hammer
Old March 22, 2009, 01:38 PM
Perineum's Avatar
Thanks for the info. I'm seeing what you mean now with the HD Tach data sitting in front of me. Looks like I'd get decent thruput even up to 300GB before it starts bombing out....
Edit: When do I get my Folding tag? Anyone? I'm #60 now
Old March 22, 2009, 01:46 PM
Did you post in the thread tittled Tag requests here? thats more of a question to be aimed at that thread.
The main reason I partition and short stroke is to make my hard drive more "modular" I can format data A without effecting data B. Or defrag Data A without having to do Data B. There are many benefits to having a partitioned hard drive besides any performance gains. But it is nice to know that my crucial programs have the fastest 10% of the hard drive while my stored files that arent used often occupy the last 40%.
The Builders Hammer
Is it possible to short stroke my winki? CMetaphor Off Topic 5 March 5, 2009 05:10 PM
ESata dual raid enclosure = poor man's hardware raid? sswilson Storage 10 May 6, 2008 09:58 AM
Distilled water spills can short out computer parts?? Dashock Water Cooling 6 May 5, 2008 11:29 AM
Raid Array Questions? Robscix Storage 13 December 5, 2007 02:59 PM
A short guide to memory terms from maxitmag Babrbarossa RAM 2 May 15, 2007 07:05 PM
