You probably made a 300G partition on the WD drive and the rest of the drive is unpartitioned. Just right click on "my computer", go to "Manage" and then select "disk Management" from the menu on the left. You should see all 3 drives with the drive letters and partions. Select the un-used space on the WD and right click again and go about adding a new partition.
The only other option to to reformat the drive and use the WD tools to transfer your C drive to the WD drive without making a smaller partition.
__________________ GAMER: Win7 Pro x64, Q9550 @ 3.6Ghz (Coolit ECO A.L.C.), Asus P5Q Pro Turbo, XFX 6950 2GB (EK FC watercooled), Gskill 4x2GB DDRII 1066, OCZ Vertex + 120GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX620W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 2x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, ATI 3450 512mb passive, Intel Pro PT Gbit, Corsair 400W PS & Antec 300. |
