  #21 (permalink)
Old March 4, 2009, 09:25 AM
Soultribunal's Avatar
Originally Posted by AkG View Post
Which model ST? Solid? Apex? or Vertex?
OCZ Solid Series 120GB I believe.
I know it wasn't the highest end one out there when he picked it up.
ST
www.realhardwarereviews.com
  #22 (permalink)
Old March 4, 2009, 09:32 AM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
Hey its still a good drive. Was more curious than anything....BUT future reviews may give you a few hints to pass on to 'em on how to get the best from it ...just saying you never know what nuggets will be in there (especially the OCZ one).
  #23 (permalink)
Old March 4, 2009, 09:47 AM
Oh I'll bet it can do lots, and of course I'll just sit around and wait till you guys tell me how lol!
Funny thing is, he is one to go get the latest and greatest parts out there...and then sit and stare at them because he doesn't know what he wants to do with it lol.
ST
  #24 (permalink)
Old March 4, 2009, 10:00 AM
AkG's Avatar
AkG AkG is offline
LOL....let me rephrase that....some Solid owners who are first time SSD users MAY find some nuggets in there ;)
  #25 (permalink)
Old March 4, 2009, 10:06 AM
I'll point him in this Direction then :)
ST
  #26 (permalink)
Old March 4, 2009, 06:28 PM
lowfat's Avatar
I don't suppose you could tell me what config you used for IOMeter? I installed MFT on my system and forgot to run it before I installed it. So I want something to compare it too.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #27 (permalink)
Old March 5, 2009, 05:50 AM
AkG's Avatar
AkG AkG is offline
NP from lowfat.
Do a std. Default install to a good fast C drive, make the test drive D and have no other devices attached to the system (also disconnect any NAS or SANs or any lan connections...it makes a slight dif BUT a dif none the less). Then remove all the default tests and create 8 tests one by one. Call 'em 512b, 1k, 2k,4k,8k,16k,32k,64k and make the transfer size of each the same as the name ;)
Make it 100% Random and leave it to 100% access spec. Drag the slider to 80% read / 20% write. Leave everything else as default.Set the ramp to 20 seconds and run time to 10 min. For each test run change the Que depth to 1,4,16,64, or 128....and let her rip. In the csv file add up all 8 test scores, divide by 8 and presto you got a number which will directly compare to ours. :)
  #28 (permalink)
Old March 5, 2009, 11:46 AM
lowfat's Avatar
Did you run each test individually for 10 minutes or add them all then run for 10 minutes? I don't know if I understand iometer fully yet.
And I don't see this que depth anywhere, I did the rest though. and am currently running it
EDIT: I see now, it runs 10 minutes for every test. Now the drive wasn't completely empty. It had 30GB or so used up, will that affect results? Because currently Iometer is taking ever last byte of the drive.
Queen of Dreams WIP
Big Lian Li
Complete
  #29 (permalink)
Old March 5, 2009, 12:03 PM
AkG's Avatar
AkG AkG is offline
Basically when you make your 8 subtests add them to "assigned access specs" side of that tab. It will run each of the 8 tests for 10min 20seconds (20second ramp up where drive is warmed up but results are not counted). Que depth is set on the Disk Targets tab. Its called number of outstanding IOs...or something like that. Set it to 1,4,16,64, or 128. Walk away from computer (turn of screen saver, and power saving options!). Come back in 80 odd minutes, set que depth to the next setting. Run it again BUT Save the results to a NEW CSV file. ( I used for example x25m_IOMeter_results1.csv, and changed the 1 to 2 4 16 64 or 128 for each test).
So to set time you set it in the Test setup tab
to Set subtests (and make them) you use the Access Spec tab
to set que depth and drive to test you use the disk targets tab
Hope this helps
  #30 (permalink)
Old March 5, 2009, 12:29 PM
lowfat's Avatar
whoa, so you ran it for 80minutes for each 1, 4, 16, 64, 128?
Queen of Dreams WIP
Big Lian Li
Complete
Intel Core i7 920, 940 & 965 EE Review Comment Thread MAC CPU's and Motherboards 67 January 27, 2009 07:00 PM
BFG GTX 285 OCX Review Comment Thread SKYMTL Video Cards 8 January 21, 2009 02:55 PM
[FS] Intel X25-M 80GB SSD Drives Linus Buy/Sell & Trade 13 January 4, 2009 02:57 PM
BFG GTX 260 Review Comment Thread SKYMTL Video Cards 33 November 15, 2008 11:26 PM
