Old February 15, 2009, 08:49 AM
Default LG drive broken?
So i bought most of my parts for my rig last summer, and kinda recently i just switched out cases, installed vista ultimate 64-bit, everything was great, then i started some sleeving and cable mangement...after i put everything back, my dvd drive didnt turn on anymore...i thought it was cause i used a faulty molex 4-pin to SATA power to power the DVD drive, maybe i burnt it out when i was doing my uber noob sleeving.
So i got new molex to SATA power, and nothing..didnt turn on..so i decided "okay i'll try direct from psu"....nothing -_-
bought from CC
i think it was like a g20 model, gotta double check on that though..sigh
btw. never had any problems burning anything...besides the few bad dvd movies which coulda been the discs
CPU:Intel i5 6600k - Corsair H110
GPU:EVGA GTX980Ti FTW Edition
HDD:250GB Samsung Evo 850 SSD, 3TB WD Black
MOBO:Asus Z-170 Deluxe
RAM:G.Skill Ripjaws V F4 2800mhz 16GB
PSU:Silverstone 950W
CASE:Silvertstone TJ07
Keyboard:Logitech G15 V2
Mouse:Razer DeathAdder
Case Cooling:2x92mm exhaust,2x120mm exhaust, 2x120mm Ultra Kaze(3000RPM)intake.
Running:Win7 64-bit Ultimate
Old May 31, 2009, 05:16 PM
clone63's Avatar
I had a drive that did this, although mine just started to work again without reason. Try a different connector, maybe ones that already connected to a device you know works. Maybe try the drive in different computer with different power supply altogether.
Old May 31, 2009, 08:08 PM
Perineum's Avatar
PUT IT IN THE OVEN!!!111
Old May 31, 2009, 08:57 PM
Silvgearx's Avatar
SPAM!
anyways, thats a really odd problem you have there. have you tried a different sata power outlet? altho i am sure you did.
and you mean you sleeved the PSU cables right? your probably had to take apart the sata part to place the sleeves in. try taking it apart again and carefully put it back together.
Do you have another PC or PSU that you can test?
Old May 31, 2009, 09:03 PM
Jake_HT's Avatar
This was a few months ago?
http://jakeht.deviantart.com/
Old June 1, 2009, 06:29 AM
Soultribunal's Avatar
Save yourself the Pain and frustration and grab a new one.
That is almost how my LG Drives went (3 in total).
Mind you, I did forgive LG and started to buy their Optical drives, but I find sometimes its a lottery with them...
Grab a Sammy or Sony Optical and move on from that one.
After of course, you run through all the troubleshooting on it.
Regards,
ST
www.realhardwarereviews.com
Old June 1, 2009, 12:43 PM
Perineum's Avatar
Originally Posted by 5ILVgeARX View Post
SPAM!
Nah, just referring to this thread:
http://www.hardwarecanucks.com/forum...card-bake.html
Old June 6, 2009, 02:13 PM
Realityshift's Avatar
You try a different Sata cable? I was having some really problems with my DVD writer that had been working fine before but just started to go nuts, a cable change fixed it completely. Its an LG also...
The Builders Hammer
what do you do if your car is broken into? CTA Off Topic 31 March 1, 2009 12:17 PM
My dog is broken Phobia Off Topic 11 January 21, 2009 12:47 AM
repair some broken hardwares CTA Off Topic 18 October 14, 2008 08:27 AM
