Old January 24, 2009, 12:51 PM
punk_zappa's Avatar
What you can do is create a separate partition for your files and OS so you can at least try and see for yourself. As for my personal experience, it is ok. My son is currently using it and see if it will BSOD with all the crap he is doing. So far it is running great.
Old January 24, 2009, 02:19 PM
Any DVD will do - but you have to select ISO burn in your software.
Like Charlie said. I personally use imgburn, free software. Burning an ISO is the easiest thing on it.
Old January 24, 2009, 03:17 PM
Infiniti's Avatar
Eh, I use Burnatonce. I find it even easier. You just mount the image, pop in the disc, and click the button. Done.
Old January 29, 2009, 07:50 PM
rjbarker's Avatar
ImagBurn....is free....
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old January 29, 2009, 07:57 PM
Infiniti's Avatar
Burnatonce is also free.
Old January 29, 2009, 08:25 PM
Betas are put out for a reason.
To have it tested by those that will use it and abuse it.
These programs are never to be trusted as a primary os.
This is stressed on the windows 7 site! :rtfm:
Please heed their warning.
Least you get very pissed off with a crashed system and lost data.
My Rig
Intel i7 940
Rampage II Extreme MB
Corsair 6GB memory
Seagate 1.5TB HDD, Seagate 500GB HDD
BFG (Geforce GTX 295)
LG Blue Ray + HD Combo Optical Drive
Cooler Master HAF 932 case
Corsair HX1000 power supply
Samsung T260HD 25.5" LCD Monitor, NEC 1860NX 18" LCD Monitors
Cambridge Soundworks 2.1 Speakers
Logitech keyboard and mouse
MS Vista Ultimate 64bit.
Old January 29, 2009, 09:02 PM
rjbarker's Avatar
Huh....?
Timespy: 18.613K
MARK 11: 40.185K
Old January 29, 2009, 09:06 PM
Infiniti's Avatar
Originally Posted by Zippoh View Post
I see, awesome. Now is it safe to use winows 7 as a primary OS? or is it a smarter choice to partion my hard drive for windows 7?
Originally Posted by rjbarker View Post
Huh....?
He made a nice little poem like thing for the OP.
  #19 (permalink)
Old January 29, 2009, 09:48 PM
rjbarker's Avatar
Cute...
Timespy: 18.613K
MARK 11: 40.185K
  #20 (permalink)
Old January 29, 2009, 10:36 PM
ipaine's Avatar
Hey since a bunch of you are using/have used win 7, may I ask what anti virus you have that works on it? Just wondering cause I am starting to test it on a couple stand alone machines at work but was having issues with our endpoint 11 not working right.
Oh and as for burning I usually use ultraISO, but as for free ISO recorder works well.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Need a burning software to backup my movies? mazabe O/S's, Drivers & General Software 8 November 19, 2008 09:28 AM
Best DVD Burning/Ripping Software? bojangles O/S's, Drivers & General Software 3 October 11, 2008 10:43 AM
DVD-RW burning time... omgwtf Troubleshooting 7 April 13, 2008 08:11 AM
Best CD/MP3 Disc Burning Program TwystedMonkey Off Topic 4 March 14, 2008 05:50 PM
BIOS Chip burning JShupka Troubleshooting 13 January 22, 2008 11:21 PM
