Originally Posted by enaberif That's because Seagate sees the consumer as just that. Not someone who may know how to do it themselves.. and even if you did you run the risk of bricking the drive.
Firmware is out there. |
Using that logic I should have to jump through hoops to get a motherboard bios update?
This is utter BS, if there is a firmware update for our drives, make it available on the site and give some info on it ( I'm not flashing my drives with firmware from somewhere else)
This isn't the only firmware glitch they've had with the 7200.11 drives, some of the SD04 and SD14 ones had to be flashed to see the full amount of cache.
