Originally Posted by Phobia wouldn't raid 1 make more sense 3 of 7? for backup? |
Two things;
A. Raid is NOT BACK UP, it simply protects from disk failure but NOT data loss. If your finger slips and you format a drive, get infected with a virus, or some bug hoses your file system, no amount of raid will save you.
B. 3 of 7 uses it as a temporary holding area while he fixes clients computer, the data stays on the drive for no more than a couple hours I'd guess.
Again, I haven't had my morning tea yet.
3 of 7, that Samsung drive should work great for you! Its a good, fast, stable, reliable drive. You might find some of the F1 series drives being bashed on the net for higher than usual DOA rate(they either worked forever, or dead within a week), but it only affected the 1TB drives, and its been solved by now.
