Old January 7, 2009, 04:43 AM
Default USB flash drive space detection problems
So I picked up a 16gb Patriot xporter on sale from NCIX a few weeks back and it's great, no more clunky portable hard drive!
But I lent it to my friend as he needed one to try something with Norton Ghost.
After I got it back, my nice 16gb got reduced to 1.90gb
I figured a quick format would fix it... nope! After that didn't work I decided to investigate the problem further using disk management.
I tried re-formatting it there. Still nothing.
Then I noticed there was 13gb of unallocated space. Great, I'll just re-partition this and... it's all greyed out!
At this point I am stuck. I've tried just about everything I could think of.
Any suggestions guys??
Here's an image for clarification...
Old January 7, 2009, 08:40 AM
3.0charlie's Avatar
I don't know much about partitions, but can't you extend the volume?
The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV
Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
Old January 7, 2009, 02:02 PM
Nodscene's Avatar
Unfortunately Windows doesn't give you too many options when it comes to partitions. You will need a separate partitioning program if you want some of the advanced options. I'm not sure what there is in the way of free ones but Acronis makes a good one, just not free.
Create something idiot proof and they will make a better idiot.
_____________________________________
Intel Q6600 - Gigabyte EP35-DS4 - OCZ Reaper 4gig PC2-6400 - XFX 8800GT 512Mb Alpha Dog - AuzenTech X-Fi Prelude - Alesis M1Active MK2 - Corsair HX-620 - Silverstone Temjin TJ05B-X - Scythe Katana 2 - WD Raptor 150Gb - Seagate 7200.11 750Gb x2 - Samsung SH-S203N
Old January 7, 2009, 02:05 PM
GParted -- Live CD/USB/PXE/HD
Should be able to recognize your USB flash drive.
Old January 7, 2009, 11:01 PM
ah alright that may work...
I'll look into it.
I heard partition magic is quite good.
I'll let you know how it goes.
Old January 7, 2009, 11:55 PM
SugarJ's Avatar
I've been able to grow and shrink partitions using Vista's built in partition manager.
If you're using XP, you'll have to use one of the programs mentioned above.
How to resize a partition in Windows Vista | Vista Rewired
Comment Thread for 2GB Flash Drive Roundup SKYMTL Storage 4 May 16, 2007 06:17 PM
Nuke-proof Flash Drive for the Military.... Supergrover Reviews & Articles from the Web 0 February 17, 2007 07:52 AM
