Old January 5, 2009, 04:34 PM
Default Mounting a 3.5" HDD into a 5.25 Optical drive bay using scews
how would I do that? I seen some brackets online but I prefer buying in-store, could I find something similar at Canadian tries.
Old January 5, 2009, 04:50 PM
SugarJ's Avatar
Go to any mom & pop computer store, you should be able to buy a proper adapter for $5.
Old January 5, 2009, 05:07 PM
I see. I managed to install it to one side with one screw, it's supports by these edges under the screw hole, it seems safe.
Old January 5, 2009, 05:18 PM
Yah how about no.
Old January 5, 2009, 05:24 PM
Originally Posted by enaberif View Post
Yah how about no.
What could happen? it's secure and so far no problems.
Old January 5, 2009, 05:28 PM
No its not secure.
You have two screws into soft aluminum with the height of the hdd floating in air on the side.
What happens when you put more weight on one side of a balance? It tips.
Old January 5, 2009, 06:41 PM
kirk_d's Avatar
I believe you're looking for something like this.
Local puter shops should carry them.
Not worth anymore than $5
Opty 170(naked) @2600 | Abit AT8 32x | EVGA Vanilla 8800gt 650/1625/950 | 2gb Ocz Pc4000Eb@260 | Audigy Gamer | Tx650 | Cm690 |
WC Loop: DD Cpx-Pro | HWL 240 Xtreme | D-Tek V2
Old January 5, 2009, 07:05 PM
Don't play with fire - your HDD should be PROPERLY secured, all 4 screws. The brackets, as shown above is what I use, it's the best method, unlike those 5.25 adapters, because it provides for the best airflow around your hard drive and below and it's solid - those brackets can be a bit tricky to mount on the HDD, make sure you get a short screwdriver for that and properly align the brackets on each side so its level - once installed on both sides, leveled, you can "slide" it in your 5.25 area and screws in all 4 holes - you DON'T want to keep it in place with 1 or 2 screws only - that's why the 5.25 bays have 4 holes, for a purpose, to keep everything balanced and the weight spread equally.
Nige's 939/SODIMM/psu/optical drive sale **SODIMM memory added 09/24/08** nige Buy/Sell & Trade 15 October 24, 2008 07:17 AM
3.5" USB Hard Drive Enclosure (IDE) tester3000 Buy/Sell & Trade 4 August 1, 2008 08:58 PM
Mobo, CPU, Optical drive, HD, and more NEW! tgraszat14 Buy/Sell & Trade 2 June 10, 2008 03:56 AM
hp ml150 drive mounting badbob233 Storage 1 January 29, 2008 12:41 PM
Verical vs Horizontal Hard Drive Mounting Johnboy Storage 4 October 12, 2007 12:28 PM
