Old January 1, 2009, 06:01 PM
Default slot-loading optical drives
I was wondering if there were any slot-loading 5.25" drives out there(with DVD playback at least). burning performance isn't a factor for me(i rarely find the need for it). full-height is preferable.
Old January 1, 2009, 10:08 PM
Negative.
The only time you'll effectively see these are in macs and they have a ton of issues.
Old January 2, 2009, 03:05 AM
MacJunky's Avatar
Actually, Macs with slot loading drives use notebook size ones, not a big 5.25" one that would nicely fit in your PC's 5.25" bays.
I have only ever seen one normal sized 5.25" slot loading drive as far as I am aware but it was 50 pin SCSI and made by Pioneer.
Pioneer DVD-ROM U05S to be exact.
There is probably a PATA version but I doubt SATA.
If you want to see what I mean about the SL SCSI drive look at what this guy did to his old Mac.
Putting My 6500 under the knife... -- The 6400 Zone - Forums <- initial thread
Update: Putting My 6500 Under the Knife (Blue Cathodes) -- The 6400 Zone - Forums <- update
Old January 2, 2009, 06:51 AM
b1lk1's Avatar
Originally Posted by enaberif View Post
Negative.
Wrong.
Pioneer makes them. They are IDE only and they are not the easiest to find. You can also find SCSI units but they have obvious limitations. Try Ebay as I don't believe they are in the retail channels any more as well.
Pioneer DVD-106S DVD-ROM drive slot-loaded - (eBay.ca item 220328934637 end time 11-Jan-09 16:02:44 EST)
That one is IDE and there are also a few SCSI ones as well. If you need it black then spray paint is your friend.
MY HEATWARE
Old January 2, 2009, 06:55 AM
Originally Posted by b1lk1 View Post
Wrong.
Right.
The reason you don't see these in a PC for is because they are loud, noisy and have high failure rates.
Old January 2, 2009, 06:58 AM
b1lk1's Avatar
I always wanted one, but they used to be expensive and not worth it since they are read only. I have to agree that they are not the best idea on the planet.
MY HEATWARE
Old January 2, 2009, 02:29 PM
NyteOwl's Avatar
Samsung made an external though I don't know if it's still available.
Obsolescence is just a lack of imagination.
Old August 4, 2009, 09:43 AM
Trial Member
Wink Problem Solved!
Hi everyone,
I've found a great solution for 5.25" slot load that is actually quite dependable and a prefect fit for my custom system. I scoured the market for any kind of slot loading Blu-ray burner and wasn't able to find anything in production. I found that there aren't any manufacturer's who create this particular spec.. luckily I happened to stumble upon this soluton from Sunland International and Digistor.
Digistor 5.25" Blu-ray Writer SATA (Slot Load)
This is a chassis system which costs $28 bucks and allows you to fit ANY 12.7mm slot load optical drive into your 5.25" drive bay! The company sells a full kit which has an integrated Panasonic drive - or you can just buy the chassis alone and use any kind of drive you want. Since you can choose any 12.7mm drive - it makes the product much more dependable since the choice is yours - I prefer Panasonic for slot load drives based on my experience. Check it out, this from what I hear is the only 5.25" solution for slot load optical drives worldwide (I've definitely spent the time to find this out firsthand!).
Thanks,
M.
Old August 4, 2009, 11:02 AM
Dr_BenD_over's Avatar
I had a Pioneer SCSI one, about the only drive I ever saw actually come close to it's rated transfer speed when ripping.
If it's stupid and it works, it isn't stupid.
Old August 5, 2009, 10:29 AM
Seems like slot loading optical drives aren't so available.
I also thought about the drives.. I got a little one who gets his kicks from ejecting the dvd drives of our players and computers.
Help with CoD5 not loading maps D4ng3r Gaming 9 January 6, 2009 03:04 PM
Crysis Warhead loading problem. Sniper Gaming 2 November 10, 2008 03:11 PM
[For Sale/Trade] iMac G3 Indigo Case (Slot Loading) ~pcwiz Buy/Sell & Trade 3 January 4, 2008 02:45 PM
Magnetic interference on optical drives? sswilson Storage 1 August 2, 2007 05:30 PM
Will be putting an 8800GTX, 2 hard drives, and an optical into a Silverstone Sugo! Misoprostol Cases 8 January 28, 2007 04:30 PM
