Old December 27, 2008, 09:54 PM
Default eSATA Cable Length Question
I need to move my external drive a few feet, but it uses an eSATA cable. The cable supplied with the enclosure is only 2 feet or so, but I need 5-6 feet. I saw a 6 ft cable on DirectCanada that should be ok lengthwise. Will the additional length present problems for this drive?? The enclosure is an Antec MX-1 and the drive is a Hitachi Deskstar 750G.
Thanks.
ASUS Z97-DELUXE; INTEL i7 4790K ; NOCTUA NH-U12P; PNYGeForce GTX 760 OCX ; LIAN-LI PC-V1020 CASE; SEASONIC PLATINUM 860; WINDOWS 10 PRO 64-BIT.
Old December 28, 2008, 01:24 AM
MonsterSound's Avatar
From what I read, the passive limit is 1 meter, but the eSATA HBA cable length can be up to 2 meters. WikiP
2c
Code:
 my Heatware,  RFD &  eBay
MAIN: i5 3570 @ 4.5Ghz wH100 / evga GTX780 SOC / MSI Z77A-G45 / 8gb G.Skill 2133 1T / 30" 2560x1600 / Antec P280 / PCP&C 950w / Intel 520 SSD 240gb / Eclipse / G3-Lazer / z5300 / Win7 Pro64 / APC Xs1300
HTPC : nMedia6000B / AMD X2 4400+ / M2A-VM / Corsair 4GB 800 / LiteOn Blu-Ray / 8800GT / Samsung 46"LCD / 2x2TB / OCZ500 / ATI550 / Wrless Kbrd & Rmte / z-5500 / Win7Pro / APC700
"You must be the change you want to see in the world"
- Mahatma Gandhi
Old December 28, 2008, 08:42 AM
Thanks for the post - and the links. I have ordered a 2M cable and will provide an update when everything is connected and tested.
Looking for feedback on using esata yamawho Storage 9 December 27, 2008 05:36 PM
Search string length zlojack Suggestions & Feedback 2 November 14, 2008 03:31 PM
Crucial Ballistix DDR2-1066 Died? (More Epic Length) tehgooch Troubleshooting 11 July 21, 2008 07:44 PM
HDMI Cable Question Supergrover HTPC Systems & Software 11 June 30, 2008 07:53 PM
dose the length of warranty really matter to u? cmhyt Video Cards 7 December 17, 2007 07:57 AM
