Old December 10, 2008, 11:12 PM
donimo's Avatar
Default new HDD noise on secondary drive after Vista reinstall?
Hi, I recently had an issue with a buggered up Windows update, obviously MS "support" wasn't very supportive. I decided to reinstall vista from scratch.
Ever since the reinstall my 640GB seagate seems to spin up, make a click sound, then about 15 seconds later spin down and make the same noise.
I never noticed this noise before, and its only cause my system is dead silent that you can hear it.
This drive never saw any action during the reinstall though, thats the point, I just keep all my important stuff on that drive for this reason.
any ideas? Vista settings or indexing or???
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old December 12, 2008, 06:12 PM
486's Avatar
486 486 is offline
Check SATA data and power cable, it may not sit tight. But generally, Seagate drives click. They should rename the company to Clickgate.
Silverstone TJ-08E
Seasonic X-660
Asus P8Z77-M Pro
Intel i7-3770
Kingstone HyperX 2 x 8GB
Crucial M4 256GB + 128 GB
Sapphire Radeon HD7970
Nec Multisync LCD2690WUXI
Old December 12, 2008, 06:28 PM
Andy's Avatar
I'm going to go with it's just Vista indexing after an install. If it keeps making noise after a week or so I would be concerned. But yah ... it seems all the new Seagate's make a lot of noise. One of my 500Gb drives just started howling. I've backed everything up and I am currently testing it.
SAGER 5165 - Matte Screen (1920x1080) - i7-2630QM - nVidia 555M - 8Gb DDR3 - 120Gb Corsair Force GT SSD - 500Gb Momentus XT - Intel® 6300
Old December 12, 2008, 10:11 PM
That's not true. There are different types of noises a HDD make. Yes seagate uses offline diagnostics on their drives, and you may hear occasional seeking noises, like when you access data, but it is usually temporary. However, the loud "klonking", sounds some people report or other continual noises is NOT normal. I have so many seagates drive I could open a store including 320 and 500GB, and none of them make ANY noise - they run 24/7. The only noise they make is the faint seeking "click" during offline self testing, but it lasts only a minute then stops then remains quiet.
Clickgate. Now that's interesting, but unoriginal. How about SeaClicks ?
Old December 12, 2008, 11:50 PM
rjbarker's Avatar
I find my Seagate Drive dead quiet compared to my 74GB Raptor.....that thing sounds like a heard of water buffalos running around in my case!
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old December 13, 2008, 09:35 PM
donimo's Avatar
it is faint if I had anything louder than an antec tricool on low I wouldnt hear it.
It is like a faint CLICK, then a whirr, then a click about 30seconds later and a whirr down...
I report back in a week, or is this normal (my first seagate)
Old December 13, 2008, 10:57 PM
rjbarker's Avatar
Seagates click...its normal.
How to Share the Root of a Drive Under Vista Misoprostol Guides & How-to's 46 August 10, 2012 06:49 PM
LF: Cheap Nvidia card for secondary display Jackquelegs Buy/Sell & Trade 3 September 6, 2008 02:02 PM
Optimize USB Drive Performance in Vista Hardware Canucks Guides & How-to's 0 April 22, 2008 01:31 PM
Thinking about a secondary rig zlojack CPU's and Motherboards 4 April 9, 2008 07:03 PM
Vista problem or bad hard drive? Varroa Troubleshooting 11 February 23, 2008 05:29 AM
