  #21 (permalink)
Old November 21, 2008, 11:32 PM
Chilly's Avatar
Under "Serial ATA Controller", what options does it give you?
  #22 (permalink)
Old November 21, 2008, 11:44 PM
rjbarker's Avatar
My screen shows exactly as what you have posted.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
  #23 (permalink)
Old November 21, 2008, 11:45 PM
rjbarker's Avatar
Do you want to know what "options" I have for each item listed?
  #24 (permalink)
Old November 21, 2008, 11:50 PM
Chilly's Avatar
Just "Serial ATA Controller"
  #25 (permalink)
Old November 21, 2008, 11:54 PM
rjbarker's Avatar
Options are:
- Disabled
- SATA 0
- SATA 0 + 1
- All Enabled (which it is presently set at)
Now, my Raptor is on SATA 0, Seagate SATA 1 DVD Drive is on SATA 4....now that I think of it, prior to the swap out of all my Hardware into my new Case and the addition of my new Raptor, my DVD ROM Drive was plugged into SATA 1 (presently my Seagate), perhaps if I swap them out?...I don't know, taking stabs at the dark now :)
  #26 (permalink)
Old November 22, 2008, 12:13 AM
Chilly's Avatar
Options are:
- Disabled
- SATA 0
- SATA 0 + 1
Worth a try, unfortunately I do not know much of the inner workings of nVidia chipset based boards. If that deon't work, try "disabled". It may disable the SATA controller entirely or change into IDE mode, try it and see. Worst comes to worst, you'll have to enable it again.
Edit- I downloaded the user manual and I'm looking thru it now.
  #27 (permalink)
Old November 22, 2008, 12:16 AM
rjbarker's Avatar
Yep tried swapping out SATA Ports, now the COD WaW gets the exact same "error" message.....I'll try "disabling it and see what happens....now I know why it was suggested to install the "crack"...but that seems crazy when you spend $50 on a game!! uugghhh
  #28 (permalink)
Old November 22, 2008, 12:26 AM
Chilly's Avatar
Looking in the manual, looks like it will disable the whole controller, once you read this, put it back to "All Enabled" and then go under "RAID Config" instead and set "Raid Enable" to Disabled. Before you set it to disabled thou can you write down what options "SATA x Primary/Secondary" give when you go under them (inside the RAID Config" menu)?
  #29 (permalink)
Old November 22, 2008, 12:39 AM
rjbarker's Avatar
Yep...that was a real "BIOS Ride"...hahahahah, anyhow, disabling SATA was a no go....had to go into BIOS and set eb=verything back to "default" to get it to Boot back into Windows..hahahaha, I thought I as going to have to reset CMOS their for a minute ....will have a look at RAID..thaks again.
  #30 (permalink)
Old November 22, 2008, 12:44 AM
Chilly's Avatar
No problem, I just want to see you solve this thing without having to result to cracks or worse, having to put an IDE DVD drive in. *shudders*
