Old October 28, 2008, 10:30 PM
Default Compatability Question? Please assist!
Hello all,
I'm hoping you could answer a compatability question for me. I'm looking to upgrade to a bigger hard drive (NCIX.com - Buy Western Digital Caviar Black 640GB 7200RPM 32MB Dual Proc 3.5IN SATA Hard Drive OEM 5YR Mfg Warranty - WD6401AALS In Canada.) but I don't know if it's going to be compatabile with this system. Any help you can offer would be much appreciated! Here are the system specs:
Processor:
INTEL PENTIUM 4
CODE NAME:
NORTHWOOD
BRAND ID:9
PACKAGE:SOCKET 478 mPGA
TECHNOLOGY:0.13 um
SPECIFICATION:INTEL (R) PENTIUM (R)4 CPU 2.80
FAMILY:F
EXT. FAMILY:F
INSTRUCTIONS: MMX, SSE, SSE2.
MODEL:2
EXT.MODEL:2
STEPPING:9
REVISION:D1
CLOCKS (CORE #0)
CORE SPEED:2793.2 MHz
MULTIPLIER:x 21.0
BUS SPEED:133.0 MHz
RATED FSB:532.0 MHz
L1 DATA:8 KBYTES
L1 TRACE:12 KUOPS
L2:512 KBYTES
CORES:1
THREADS:1
CACHE
L1 D-CACHE
DESCRIPTOR:4-WAY SET ASSOCIATIVE, 64 BYTE LINE SIZE
TRACE CACHE
DESCRIPTOR: 8-WAY SET ASSOCIATIVE
L2 CACHE
DESCRIPTOR:8-WAY SET ASSOCIATIVE, 64 BYTE LINE SIZE
MOTHER BOARD
MANUFACTURER:IBM
CHIP SET:INTEL i865P/PE/G/i848P REV:A2
SOUTHBRIDGE:INTEL 82801EB (ICH5)
LPCIO:SMSC
BIOS
BRAND:IBM
VERSION:2AKT34AUS
DATE:11/21/2003
MEMORY
GENERAL
TYPE:DDR
CHANNELS#SINGLE
TIMINGS
DRAM FREQUENCY:166.3 MHz
FSB:DRAM:4:5
CAS#LATENCY (CL):2.5
RAS# TO CAS# DELAY (tRCD): 3 CLOCKS
CYCLE TIME (tRAS):7 CLOCKS
SPD
MEMORY SLOT SELECTION
SLOT#1 DDR
MODULE SIZE:256 MBYTES
MAX BANDWIDTH:PC3200 (200 MHz)
MANUFACTURER:MICRON TECHNOLOGY
PART NUMBER:8VDDT3264AG-40BCB
SERIAL NUMBER:1A4DEFEC
CORRECTION:NONE
BUFFERED:NO
WEEK/YEAR:01/04
TIMINGS TABLE
FREQUENCY: 133 MHz 166MHz 200MHz
CAS# LATENCY: 2.0 2.5 3.0
RAS# TO CAS : 2 3 3
RAS# PRECHARGE: 2 3 3
tRAS: 6 7 8
VOLTAGE: 2.5V 2.5V 2.5V
SLOT#2 DDR
MAX BANDWIDTH:PC2700 (166 MHz)
MANUFACTURER:HYUNDAI ELECTRONICS
PART NUMBER:HYMD232 646A8J-J
SERIAL NUMBER:1C1EC1B9
CORRECTION:NONE
BUFFERED:NO
WEEK/YEAR:103/49
TIMINGS TABLE
FREQUENCY: 133 MHz 166 MHz
RAS# TO CAS#: 3 3
RAS# PRECHARGE: 3 3
tRAS: 6 7
VOLTAGE: 2.5 2.5
Old October 28, 2008, 10:45 PM
Jon_di2's Avatar
Sure it would work, but not by itself, that system wont have any SATA headers on the motherboard, but you can buy a IDE-SATA Converter.
EVGA780i FTW|Q9450@3.3|2x2GB Mushkin Redline 8000|GTX 260 Core 216 65nm|Corsair TX750|Antec 900|Acer 22|Antec Multimedia Premier|WD 640GB|Seagate 500GB|Logitech G15|Vista64
EVGA790i FTW|E8400@4.1|4x1GB Aeneon Xtune DDR3-1866|2xGTX 260 55nm|CM 750W| CM690|Viewsonic 25.5|Seagate 500GBx2|Logitech G5|Razer Lycosa|Scythe Kaze Master 5.25|Win7 & XP
Dell XPS M170|Pentium M @2.00|2GB DDR2 @667MHz|Nvidia GeForce Go 7800 GTX|120GB|17" WUXGA|XP32
Old October 29, 2008, 04:26 AM
sswilson's Avatar
Or a PCI Sata card.... :)
Old October 29, 2008, 05:42 AM
much better idea... those converters aren't recommended for long term solutions.
Old October 29, 2008, 11:50 AM
Thanks for the info. From what I gather then, if I were to purchase one of these: NCIX.com - Buy Syba SD-LP-SIL2IR Low Profile 2 Port SATA RAID Controller Card PCI - SD-LP-SIL2IR In Canada. in conjunction with this card then it should work fine?
Is there anything special I would need to do in BIOS or is it simply a matter of popping that into the PCI slot and then using a sata cable to connect the drive to that card and it should work?
Thanks for all the help so far
