Hello,
I have a little problem with a new HDD I'm trying to install.
I received the drive on friday (WD blck 640 GB). I shutted my comp down, unplugged my psu, install my hdd, plugged the power cable and the sata cable. Then, I powered evrtyhing on, entered the bios to be sure that my boot setting from unchanged, checked if the drive was recognised (yes). After, I restarted my PC, loaded Vista 64, and my drive installed by itself. I formated the drive and eveything.
Everything was working fine before I decided to restart my PC again. It won't post after a restart. I have to shut it down manually, so I can have a message (Overclock failed, press F1 bla bla). I press F1, enter the bios, and restart. Then, my PC load windows and everything is fine. I just can't load windows on the first reboot, or cold boot.
When I unplug the new drive, everything is working great! Did I miss something?
This is my current confirguration :
WD 500 GB --> Booting HDD with the OS (sata 5 port) Disk 0 in Vista
WD 640 GB --> just an additionnal drive (sata 6 port) Disk 1 in Vista (not MBR disk)
Sometimes, when the boot failed, I get a Boot block message version .018. But, again, it doesn't happen when the new drive is not connected.
Help me plz
