<~----> how to prolong Hard drive life? - Hardware Canucks
Old October 20, 2008, 03:15 AM
Default how to prolong Hard drive life?
hi there, i have a 1 tb HDD and i am really scare if that drive fails and lose my data, does anyone know a good way to prolong the life of a hard drive, will leaving it on 24hours help? always put my PC to self standby.
thanks
Old October 20, 2008, 03:32 AM
dont use it:P just leave it on,the stress of the electricity heating up and coolomg off daily will male the boards flex. Turn it lon, and leave it on
Acer 5920G ( Stock Air ) no OC:P
At least its DX10!
Old October 20, 2008, 05:24 AM
Varroa's Avatar
Once every 6 months or so you could run spinrite to find and repair any bad sectors.
GAMER: Win7 Pro x64, I7 3770 (stock) (CM 212+), Asus P8Z77-V Pro, XFX 6950 2GB, Corsair Vengeance LP 4 x 4GB DDR3 1600Mhz, Crucial M4 120 GB + 256GB, Intel X25-M 160GB, 1TB WD Blk, DVD, BRD, HX750W, Auz X-Fi Prelude, Intel Pro CT Gbit NIC & CM Cosmos
Game Server: Win7 Pro x64, AMD Phenom II X4 960T Zosma, Gigabyte GA-MA770-UD3, 4x2GB Gskill DDRII 1000, 640GB WD Blk, 1 ODD, Asus 9600 GSO, Intel Pro PT Gbit, Corsair 400W PS & Antec 300.
Old October 20, 2008, 06:18 AM
MAC's Avatar
MAC MAC is offline
Associate Review Editor
thanks
If you data is important to you buy a second 1TB drive and make a backup.
The $130-180 spent now will be literally priceless should your first drive fail.
Old October 20, 2008, 06:26 AM
CMetaphor's Avatar
Quadfather
Raid 1 FTW . If one dies, you'll have no need to worry.
Old October 20, 2008, 06:29 AM
MAC's Avatar
MAC MAC is offline
I've always wanted to use RAID 1, but I'm too paranoid that whatever kills the first drive will take out the second.
So I just clone a drive and store the backup
Old October 20, 2008, 06:33 AM
Eagle Eye's Avatar
While there is very little you can do to predict the failure any mechanical device such as a HDD, leaving any electronic device on 24hrs is better than turning it on and off. As an electrical device warms up the PCB and surrounding ICs expand with the increased amount of heat until they reach their peak running temperature. I believe heat is the determining factor of the longetivity of any electro-mechanical device attaching a HDD heatsink fan solution will help prolong the life of the drive as for the mechanical properties that is where the consumer must put their trust in the qaulity of the manufacturing and qaulity control. Many HDD manufacturers spend as much time testing the reliability of their HDDs as they do building them, please review Western Digitals "promise" here WD Promise
To better understand MTBF and its common misconceptions please read this: http://www.apcmedia.com/salestools/V...GTSB_R0_EN.pdf
Old October 20, 2008, 08:21 AM
"Quote This..."
Keep it cool, use it in a well ventilated environment.
Old October 20, 2008, 11:09 AM
Mr. Gruntsworthy's Avatar
Also, make sure your drives run at as cool a temperature you can. In my antec 900 case, neither of my HDDs go over 30C (including boot HDD)
MAIN RIG:
Case: Antec 900
CPU : Intel E8400 45nm Core 2 Duo @ 3GHz 1333MHz FSB
RAM : 4GB DDR2 800MHz (OCZ Platinum)
HDD : Main: 120GB SSD (OCZ) Media: 500GB (WD) Storage: 1TB (WD)
GFX : HD4850 (512MB)
PSU : 610W PC Power Silencer
MoBo: Asus P5Q SE
View : Acer H213H 21.5" @ 1920 x 1080
Oshawa Deathmatch Community -- An open group for Durham/Toronto Airsoft, Paintball, and Nerf players. Come join!
My Game Dev website: http://mikeseguin.webs.com/
Old October 20, 2008, 11:13 AM
Eldonko's Avatar
Hardware Canucks Reviewer
My advice is always back up your data on a second drive. You can even get programs that will do that automatically for you like acronis true image.
