Originally Posted by MelodyofOblivion hi there, i have a 1 tb HDD and i am really scare if that drive fails and lose my data, does anyone know a good way to prolong the life of a hard drive, will leaving it on 24hours help? always put my PC to self standby.
thanks |
I always buy my hard drives in pair - like memory
Drives are cheap so buy them in pair and use the free acronis tool from seagate's website to make a 1:1 clone and keep it aside - and keep your backups up to date from time to time - takes only a few minutes with those drives. How to prolong the life of a HDD ? Well there is no garantee - companies are cutting corners now and a lot of people are having bad luck with hard drives failing early lately, so always be on your guard - You want to make sure your drive is level and has good airflow around it and running as cool as possible - running drives too hot over long periods of time can reduce its life or even cause them to fail - eventhough their specs say 60C - Remember the magic number, 50C, keep it below 50C. Also, use a good quality power supply - Most of the repetitive failures I've seen around me were caused by faulty or bad power supplies - drives are very sensitive to power issues.
Now, about the turning on and off a drive - I wouldn't worry about that - if you look way back at the very first generation of hard drives that was an issue, but now hard drives can easily withstand thousands of on/off cycles - of course you are not going to turn it on/off 100 times every day, but when you don't use your PC for extended period of times - keeping in mind that when you turn on your PC there is that period of startup stress on components, but if done reasonably I wouldn't worry - I personally leave my system on 24/7 - since I use my PC for work too and on a regular basis and there is absolutely no problem in leaving your system on at all times - will it increase the life of your HDD ? well it depends. A healthy HD that has no problem can withstand thousands of on/off cycles - however, and you cannot know this in advance, a drive that has a known defect, can cause it to fail - so in order to sleep well at night, just buy pairs, make a backup and leave it on ! :)
