Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Site Announcements
  #21 (permalink)
Old June 24, 2008, 03:53 PM
Gav's Avatar
Gav Gav is offline
Administrator
Alas there is no off-topic section anymore
You need to be logged in to view the "Off-topic" and "Sponsored Deals" sections.
  #22 (permalink)
Old June 24, 2008, 04:04 PM
magictorch's Avatar
Great thanks Gav Looks much nicer having just the level bar.
Now I wonder if folding should generate some sort of reward?
  #23 (permalink)
Old June 24, 2008, 04:08 PM
Gav's Avatar
Gav Gav is offline
Administrator
Originally Posted by thenewguy001 View Post
Isn't it a bit pointless for moderators though since they're usually not allowed to enter?
Fixed.
  #24 (permalink)
Old June 24, 2008, 04:12 PM
Gav's Avatar
Gav Gav is offline
Administrator
Every folding team member get's an extra entry into the sweepstakes as well. So basically, a person's # of entries would be their Contribution Level +1 if they are also folding.
I'll add that info to the sticky.
  #25 (permalink)
Old June 24, 2008, 04:21 PM
I like it..
My only complaint is this..
"Level: 9 - 63 points to level up"
Its on two seperate lines..is it possible to put a line break in there somewhere and make it on a single line?
  #26 (permalink)
Old June 24, 2008, 04:22 PM
thenewguy001's Avatar
You may also want to watch for referrer abuse. You can just go to a public library computer or internet cafe and give yourself referrer points by registering on their IP addresses
Core 2 Quad 6600 @ 2.8 GHz
2 x 2GB G.Skill PC2-8500 @ DDR2-1040 MHz
XFX HD5770
Gigabyte GA-P35-DS3L
Antec Truepower Trio 650W
Scythe Ninja Rev B w/ MX-2
CM690 w/ 1-80mm, 6-120mm fans.
  #27 (permalink)
Old June 24, 2008, 04:23 PM
Very cool idea idea Gav! I think I'm gonna split my posts between here and NCIX forums now. :D
  #28 (permalink)
Old June 24, 2008, 04:39 PM
Gav's Avatar
Gav Gav is offline
Administrator
Originally Posted by enaberif View Post
I like it..
What browser are you using? It's supposed to be in one line. Seems ok in FF3.
EDIT: Fixed.
  #29 (permalink)
MacJunky's Avatar
How about a limit of one credited referral per month with the rest giving you no credit?
  #30 (permalink)
Old June 24, 2008, 04:40 PM
Gav's Avatar
Gav Gav is offline
Administrator
Looks like it's messed up in IE7. We'll look into it.
