Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Site Announcements
Old October 27, 2014, 06:30 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default A Quick Update re: Site Issues
No, we're not being hacked again. Thank God.
Over the last while we have been gradually upgrading and relooking at various website functionality. However, this hasn't been without some issues.
As you may have noticed over the last two weeks we have had intermittent outages, some longer than others. Many of these were not planned.
After a ton of searching and what seemed like countless amounts of troubleshooting, we believe the culprit is a malfunctioning router at our hosting facility which will need to be replaced. While we own the hardware, this is not a quick fix since the component is anything but "plug and play".
Prior to replacing anything and taking the site offline for a while (no, not days if the router truly is the culprit), we will of course validate that this is indeed the problem. If that proves to be the case, an announcement will be made prior to the replacement.
Again, we apologize for the issues.
Old October 27, 2014, 07:14 PM
Cptn Vortex's Avatar
Thanks for the heads up and the hard work!
The Vortex H20
MSI Z87-G45 Gaming
i5 4690K @ 4.5GHZ
SLI GTX 1070
12GB GSkill Ripjaws X 2133MHZ CL10
OCZ Z-Series GOLD 850W
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
Old October 28, 2014, 07:26 AM
Caldezar's Avatar
Ah yes... CoLo repairs. Always my favorite part of work as well. ;)
Thanks for the heads up and I hope everything goes as smoothly as possible. I especially hop your CoLo has more space to work in the cages than ours does...
Old October 28, 2014, 11:30 AM
SugarJ's Avatar
Word from Gav is that they are going to replace a switch today, so some downtime is expected.
Old October 28, 2014, 02:30 PM
Bond007's Avatar
Thanks for the info. Good luck with it all.
Old October 28, 2014, 02:47 PM
b1lk1's Avatar
Good luck with that switch, we all know that can go just so wonderfully bad if it won't cooperate.
Driving sim: MSI 970 Gaming/FX6300/16GB Corsair DDR3/ASUS CU II R9 290X 4GB/128GB SSD+750GB HDD
Daily: Intel DQ67SW/i7 2600/8GB DDR3/WD 150GB VR+2TB HDD/CU II R9 270 2GB/Xonar D1
Old October 28, 2014, 02:51 PM
sswilson's Avatar
Apparently they've swapped out the switch so we're keeping our fingers crossed that it resolved the issue.
Old November 6, 2014, 07:11 PM
Damn it, where's our daily nerd fix?
Back up - Ebay (Inik1) or Heatware
Old November 6, 2014, 08:11 PM
I'm guessing it's NOT a plug and play switch ;-)
Mah Rig now
Mah Rig before
My stuff for sale.
Old November 7, 2014, 05:52 AM
Bond007's Avatar
Hopefully everything gets finished up soon. Good luck on the fix.
Site Issues: Announcement SKYMTL Site Announcements 9 August 12, 2012 09:49 AM
Quick fix for audio sync issues on DVD? sswilson O/S's, Drivers & General Software 6 April 17, 2009 06:15 PM
Quick update HAF cryostage Member Reviews 1 September 5, 2008 08:59 PM
Quick driver update for 2900XT Babrbarossa Video Cards 0 May 15, 2007 04:14 AM
