Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Site Announcements
  #21 (permalink)
Old July 15, 2009, 06:22 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Like I said; Furmark needs more CPU cycles than the Batch Size Test. It is an important distinction to make that the Batch Size test is NOT part of the standard 3DMark06 benchmark suite. Rather, it is one of the optional tests.
  #22 (permalink)
Old July 15, 2009, 06:28 AM
burebista's Avatar
OK, so be it.
  #23 (permalink)
Old July 15, 2009, 06:31 AM
SKYMTL's Avatar
You bring up excellent points though. Optimally, I would have loved to include tests with different programs and whatnot but it would have been a bit too complicated and alot of the results would have repeated themselves.
  #24 (permalink)
Old July 15, 2009, 06:49 AM
burebista's Avatar
SKY, to be honest all I want from your tests is how a PSU behave in real life. For synthetic tests I have some trusty sites with SunMoon but I really want to know how it is in real loads.
It will be interesting if you can test your PSU's in a closed case because with a Nehalem OC'ed and 2 HD4870X2 things are heating up quickly and you know that some PSU's don't like heat.
  #25 (permalink)
Old July 15, 2009, 07:01 AM
SKYMTL's Avatar
I will be including temperature deltas but believe it or not, I can't fit the rig in a case.... the Boreas itself takes up so much space, it isn't even funny. I had to modify a HighspeedPC Tech Station to fit the darn thing.
Here are a few pics of the process (minus the HD 4870X2s).
  #26 (permalink)
Old July 15, 2009, 07:59 AM
bojangles's Avatar
Damn that this really is MASSIVE . Oh well, now you have more space to work with from now on!
  #27 (permalink)
Old July 15, 2009, 08:10 AM
CMetaphor's Avatar
Quadfather
Sky, how easy was it to pull the pump off the Boreas? Im re-cooling Behemoth with one as part of the loop but the Coolit pump might not be up to the task, do you think the MTEC controller will freak without a Pump attached to it? hehe.
  #28 (permalink)
Old July 15, 2009, 08:17 AM
SKYMTL's Avatar
Without a pump, the thing doesn't work.
The pump hooks up directly to the controller which means the controller itself can only output a certain amount of power to the pump. If I were you, I would ask CoolIT about it and if anything, have them plumb in the pump of your choice.
  #29 (permalink)
Old July 20, 2009, 07:34 AM
wow thats some impressiv structure
A Few Interesting PSU Reviews From Jonnyguru SKYMTL Reviews & Articles from the Web 0 June 3, 2007 07:35 PM
Guru3D reviews 1100W Tagan TG1100-U95 TurboJet PSU Supergrover Reviews & Articles from the Web 0 January 10, 2007 06:01 PM
OCIA reviews 850W Etasis ET-850 PSU Supergrover Reviews & Articles from the Web 1 December 23, 2006 05:20 PM
Björn3D reviews PC Power & Cooling Turbo-Cool 1KW-SR SLI PSU Supergrover Reviews & Articles from the Web 2 December 11, 2006 03:49 PM
