Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Site Announcements
  #191 (permalink)
Old April 20, 2009, 02:15 AM
Silvgearx's Avatar
Originally Posted by Dashock View Post
185.65 is waht im usiing and very stable.
where is that 185.65 driver?
got my shader upped again
i really like this 8800gt. Had to show it off
Now just need to get that lifetime warranty sorted with the previous owner
  #192 (permalink)
Old April 20, 2009, 02:48 AM
Scratch's Avatar
how do I enter?
  #193 (permalink)
Old April 20, 2009, 04:21 AM
sswilson's Avatar
Originally Posted by Scratch View Post
how do I enter?
Just have enough points between April 15 and May 14 and you will be entered automatically... :)
If you meet the criteria as stated in the contest details above, we will enter you into the contest automatically.
HWC's staff will be keeping tracking of every eligible folder's stats, so just sit back and fold.
ASUS SaberTooth 990FX / AMD 1090T / 2X4 Gig Gskill RJ X / XFX Pro 1000W PSU / 2X MSI 560GTX-Ti Twin Frozr II / Corsair F120 / WD 6401AALS
TT Lvl 10 GT / DDCPX-Pro / EK XT 240 Rad / 2X Scythe Ultra Kaze / EK Supreme HF / XSPC 250mm Res / Dell Ultrasharp 2209WA
Asus CH IV / Athlon II X2 250 / 4X2 Gig GSkill Pi PC3-12800 / 2X GTS 450 / PC P&C 750W Silencer / PA 120.2 /
MCR220-QP-Res / Swiftech MCP350 Pump / XSPC Laing DDC top / EK-Supreme HF / Lian-Li Pitstop T60 / Samsung 931BF
  #194 (permalink)
Old April 20, 2009, 07:28 AM
stoanee's Avatar
Wow! That 8800 is kicking a$$! I may have to get my 8800 back that I gave to my son!
  #195 (permalink)
Old April 20, 2009, 08:52 AM
Dashock's Avatar
Yea thats a ridiculously good shader overclock and u can get it in the Nvidia Beta drivers theres always new ones i been using these drivers for almost 3 weeks now and cant complain. The only thing i see is your cores running pretty hot at 61 man i so wish i could hit 2000 on my shaders i dont think i can but today ill test it out when i get those 511's
Intel Xeon E3110 @ 3.0ghz
XFX 8800 GT Alpha Dog Edition
Asus P5Q-E
Mushkin Ascent Redline 8000 4gb DDR2 @ 1066 5-5-5-15 2.05v
OCZ 600W GameXstream
Seagate 7200.11 500gb
Seagate 7200.10 320gb
Antec Spot Cool
Logitech X-230
Samsung 32" 720P HDTV
Coolermaster Cosmos S/
  #196 (permalink)
Old April 20, 2009, 10:49 AM
chrisk's Avatar
Folding Captain
Thats a 353 point WU...I have had a stable shader OC on those, and then a 511 point WU comes along and spoils the party.
Still a nice chip you got there....keep a close on on the 511s though
Fold for team #54196
  #197 (permalink)
Old April 20, 2009, 11:32 AM
slugbug's Avatar
Trying a few things before I decide whether I should RMA my EVGA 9800GTX+ SC. It runs games fine but it's not so good at folding for the last few months. I lowered the core clock speed from 771 all the way down to 680mhz and was able to run a few work units to completion. Others simply refuse to run and crap out randomly with EUE and NAN errors.
I ran OCCT 3.01 on it and the graphics test found 525 errors. Is it safe to assume this card has problems and should be RMA'd?
CM Stacker830|CM Real Power Pro 650w
Gigabyte P35-DS3L|Q6600@3.0ghz
CM V8 cooler|2x1GB Buffalo Firestix PC2-6400
Maxtor 400GB|Western Digital 500GB|Pioneer 212D
EVGA 9800GTX+
  #198 (permalink)
Old April 20, 2009, 12:08 PM
werty316's Avatar
Run OCCT on your other GPUs and if no errors are found I would RMA the 9800GTX+.
Out of the blue my 8800GT started to throw out UNSTABLE_MACHINE errors and when I tested it using the OCCT GPU testing tool, it found over 15,000 errors. I tested my other video cards and OCCT did not find any errors at all.
It can run games and benchmarks just fine but it refuses to fold at all.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
  #199 (permalink)
Old April 20, 2009, 12:20 PM
chrisk's Avatar
Folding Captain
I have gotten errors in F@H like yourself, and it turned out to be a driver issue. However, I did not see if the errors also occurred in OCCT. Might be something to consider though. Try uninstalling the drivers, run driver cleaner in safe mode, and then re-install.
  #200 (permalink)
Old April 20, 2009, 01:11 PM
Perineum's Avatar
Why the HELL have I dropped from 10,000PPD to around 7000
Tags
contest , fah , folding
Folding @ Home F.A.Q. Supergrover HardwareCanucks F@H Team 229 May 15, 2010 09:24 PM
Folding@Home Passes The 5 Petaflop Mark LCB001 HardwareCanucks F@H Team 4 February 19, 2009 10:53 AM
Folding@home gpu benchmarks chrisk HardwareCanucks F@H Team 49 December 4, 2008 06:06 PM
XP Home sub $100!!!! sswilson Computer & Electronics Hot Deals 11 October 16, 2007 12:06 PM
