Go Back   Hardware Canucks > HARDWARE CANUCKS NEWS > Site Announcements
  #181 (permalink)
Old April 19, 2009, 11:12 AM
3.0charlie's Avatar
Yes, the addon cards only fold.
Unfortunately, very little market I suppose.
Hydro-Quebec is salivating...
  #182 (permalink)
Old April 19, 2009, 02:16 PM
how good is your 8800gt for folding there 5ILVgeARX ? does it make much noise? (at stock clocks)
  #183 (permalink)
Old April 19, 2009, 03:21 PM
Silvgearx's Avatar
2000 shader still going strong
as of now ppd have drop to the 4700 range, as i am also runing boinc
At stock clocks no screech sound, at 2000 shaders i can heard it loud and clear and i sit 1 feet alway from PC
GPU cooled with artic acceralo S2 with 120mm fan, 24hour load temps 59C (maybe if i add another fan it might help)
Any inputs 3.0Charlie? i notice you had an 8800gt with the same cooler and dual fans
At stock clocks 625core, 900mem, 1500shader average 4200PPD. load 24hour load 54C
  #184 (permalink)
Old April 19, 2009, 05:53 PM
3.0charlie's Avatar
Back then the GPU Client did not exist...
  #185 (permalink)
Old April 19, 2009, 07:47 PM
Dashock's Avatar
Originally Posted by 5ILVgeARX View Post
Its my first series of nVidia cards. I didn't know i can move the shader up without upping the core
Thank you for tip
Hmm, it seems like the higher the shader, the louder the screech
Do those GTX 260 series have the screech sound?
Not a problem in fact id underclock my gpu clock and memory to run the card cooler im not sure if that would give you extra room on the shaders? My card used to screech but not anymore im using 185.65 drivers you should really update your drivers i see your using the 178 ones i dont remember when the screetching stopped if it had to do with the drivers or the new projects.
Intel Xeon E3110 @ 3.0ghz-Then
Core 2 Quad Q9650 @ 3.8ghz-Now
PNY GTX 1050Ti (Coming)
Asus P5Q-E
Mushkin Ascent Redline 8000 8gb DDR2 @ 1066 5-5-5-15 2.05v
Corsair Cx600M
Samsung 850 Evo 250gb SSD
Noctua NfP-12's on Swiftech 320 rad
Logitech Z-625 setup
Sony X800E 43" 4K HDTV
Coolermaster Cosmos S/
  #186 (permalink)
Old April 19, 2009, 07:52 PM
Dashock's Avatar
I noticed you got your shaders to 2000 and you bascially have the same card i have i thought 1836 was high lol yu got a real lucky card there. And i can hear a slight screetch i have to actually listen to it it used to be muuchh muuuchh louder lol almost didnt notice it. You got the 2000 without a volt mod?
Asus P5Q-E
Corsair Cx600M
  #187 (permalink)
Old April 19, 2009, 08:06 PM
Silvgearx's Avatar
I have no clue, i am the second owner, how do i check if its volt mod?
I am using 178.24 cause LCB001 said its the most stable driver as of now
Is it still?
anyone having trouble with the newer drivers?
if its keep going till midnight then it be 24hour stable
  #188 (permalink)
Old April 19, 2009, 10:37 PM
Dashock's Avatar
185.65 is waht im usiing and very stable.
Asus P5Q-E
Corsair Cx600M
  #189 (permalink)
Old April 19, 2009, 11:51 PM
Perineum's Avatar
I managed on getting 750 core / 1900 shader / 2100 mem on my BFG 8800GTOC...... I couldn't get my shaders much higher than that even with everything clocked stock.
Now a different question....
I can't seem to find a screensaver style folding client.... is it possible that these methods would work? Anyone know of a better idea?
How to write a 32bit screen saver
How to Convert an Executable File Into a Screensaver | eHow.com
  #190 (permalink)
Old April 20, 2009, 12:31 AM
Dashock's Avatar
Doing that would slow your ppd so it wouldnt be the best course of action.
Asus P5Q-E
Corsair Cx600M
Tags
contest , fah , folding
Folding @ Home F.A.Q. Supergrover HardwareCanucks F@H Team 229 May 15, 2010 08:24 PM
Folding@Home Passes The 5 Petaflop Mark LCB001 HardwareCanucks F@H Team 4 February 19, 2009 10:53 AM
Folding@home gpu benchmarks chrisk HardwareCanucks F@H Team 49 December 4, 2008 06:06 PM
