Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old September 2, 2008, 02:16 PM
mailaw's Avatar
Level up: 94% Level up: 94% Level up: 94%
Level: 8 - 12 points to level up
Definitely not worth that much money, at least currently.
Old September 2, 2008, 02:29 PM
magictorch's Avatar
Level up: 9% Level up: 9% Level up: 9%
Level: 18 - 804 points to level up
Waste of money.
The 4870 512mb uses its DDR5 memory more efficiently than Nvidia DDR3 cards so its not worth comparing the two in terms of absolute memory.
If you game on 30inch LCDs you might as well just get the 4870X2 for future titles. For 1900 and below the 4870 512mb will be fine even with the upcomming releases. Plus they use AA more efficiently than nvidia cards which helps.
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
74gb Raptor for OS, games
Thermalrock Dragon Case (sprayed black).
Loop 1: MCR 220 int. ; Apogee GT block.
Loop 2: MCR 320; Swiftech Res.;
2x EK FC blocks.
Pumps: 2x MCP655.
Old September 4, 2008, 05:07 PM
Level up: 44% Level up: 44% Level up: 44%
Level: 4 - 29 points to level up
At that price (400$), get the GTX 280 1Gb. It's guaranteed to perform better.
Old September 4, 2008, 05:52 PM
CanadaRox's Avatar
Level up: 47% Level up: 47% Level up: 47%
Level: 10 - 150 points to level up
Originally Posted by magictorch View Post
The 4870 512mb uses its DDR3 memory more efficiently than Nvidia DDR3 cards so its not worth comparing the two in terms of absolute memory.
I believe you mean GDDR5 and GDDR3.
QX9650 @ ... | Asus P5Q-E |2x2GB Dominator @ ...
VisionTek 4870 @ 825MHz/4.6Ghz|WD 640GB Black
PCP&C 750W Silencer | HT Omega Claro
X3350 @ 4187MHz
Old September 5, 2008, 11:24 AM
magictorch's Avatar
yes-
E6750/ Xeon 3350
DFI X38 LT
2 x 4870
2x EK FC blocks.
Pumps: 2x MCP655.
Old September 7, 2008, 11:20 PM
Level up: 32% Level up: 32% Level up: 32%
Level: 4 - 35 points to level up
Woohoo! A new hope: Diamond Radeon HD 4870 750MHZ 1GB GDDR5 PCI-E 2XDVI-I Video Card - DirectCanada
Just noticed it today. Not yet available but at least the price is 'more like it' compared to the previous ones!
