Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old August 21, 2013, 09:55 AM
rjbarker's Avatar
Well... I did pay $150 for 4X4GB Mushkin Redline 2400Mhz RAM
Why do you find it easier to get HIGH OC's when NOT using the fastest ram out there? Some sort of 'strapping' conflict???
Its easier on the IMC of the Chip when running slower RAM speeds and not populating all RAM Slots, generally easier to reach higher CPU speeds. Takes more tweaking is all with no guarentees.....personally I'd much rather have a system with higher CPU speeds and lower RAM speeds.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old August 21, 2013, 05:16 PM
mattydies's Avatar
OK... ok. I think I've read that before. Either way it makes sense and I would much rather CPU speed also. With my Gigabyte Assassin2 mobo I could tune the ram seperately from my CPU. So I could easily drop the speed of my ram (Lower than it's rated speed to make it easier on the IMC) without directly affecting the CPU (or the OC). Hense my wondering why slower RAM (Not slower settings) would be beneficial to Overclocking.
Old August 27, 2013, 06:43 PM
The CPU still handles your RAM and has to constantly talk with it. The more work your CPU has to do "keeping up" with your RAM (i.e. more channels populated, higher speeds) the more it takes away from your over-clocking headroom. This analogy is not technically accurate ofc. Even though you think you can tun the RAM seperately from the CPU, they are still linked in a manner. Also, you run the risk of your RAM causing crashes when run out of spec and making your system unstable.
Old September 1, 2013, 05:15 PM
Oversized Rooster's Avatar
While I disagree with this point "Its easier on the IMC of the Chip", I do agree with your statement that populating ALL RAM slots reduces OC headroom.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old September 1, 2013, 05:33 PM
sswilson's Avatar
Outside of extreme benchers who can benefit from that extra little bump that higher clocked memory can sometimes get them, I've always seen higher spec'd memory as giving me more options WRT bus speeds to bump CPU clocks rather than something that was going to give me a performance boost on it's own. These days we don't run into it as much because CPU clock speeds are mostly controlled by unlocked multi's as opposed to higher bus speeds X locked multi's, but in the past it was often memory limits holding back CPU OCs.
I'm sure the benchers will chime in if they see this thread, but for as long as I can remember, higher CPU clocks almost always trumped higher mem speeds by a wide margin.
Old September 3, 2013, 09:17 AM
rjbarker's Avatar
Open ended, please explain......they my experience OC'ing a "weak" IMC on a CPU immediately rears itself as I progress they OC'ing.....some Chips just plain suck when trying to run say 1866 vs 1600 or 2133 vs 1866.....
Swapping out Chips with the same and low n behold the Chip may handle the higher Memory speed fine.....I figure tapping the IMC as the culprit is a reasonable conclusion ;)
MARK 11: 32.530
Why I don't trust google or the likes Shadowmeph Off Topic 5 February 9, 2013 02:02 PM
My wife likes, I feel handcuffed - IPAD Mark Mac 2 March 28, 2011 03:49 PM
Its actually fast now Eagle Eye Off Topic 14 May 9, 2009 12:11 AM
Changed the site again! Me likes! Cptn Vortex Suggestions & Feedback 3 December 13, 2007 02:39 PM
The Barcelona is fast, REALLY FAST!: AMD Babrbarossa Press Releases & Tech News 2 April 25, 2007 08:02 AM
