Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old May 28, 2013, 03:39 PM
Default AMD Radeon HD8000 Specs
HD8970
Curacao XT 28nm制程 GCN2.0架构 3个几何引擎 8个ACE2.0 55亿晶体管 420mm2
36CU 2304SP 144TMU 48ROPs 384Bit 6GB GDDR5
1100/7000MHz 250W
浮点性能: 5.07TFlops
US599 4299元
vs HD7970GHz +35%
HD8950
Hainan XT 28nm制程 GCN2.0架构 2个几何引擎 8个ACE2.0 35亿晶体管 270mm2
28CU 1792SP 112TMU 32ROPs 256Bit 4GB GDDR5
1200/7000MHz 190W
浮点性能: 4.30TFlops
US399 2799元
vs HD7970GHz +10%
HD8870
Hainan Pro 28nm制程 GCN2.0架构 2个几何引擎 8个ACE2.0 35亿晶体管 270mm2
24CU 1536SP 96TMU 32ROPs 256Bit 2GB GDDR5
1100/6000MHz 160W
浮点性能: 3.38TFlops
US299 2099元
vs HD7870 +40%
HD8850
Hainan LE 28nm制程 GCN2.0架构 2个几何引擎 8个ACE2.0 35亿晶体管 270mm2
20CU 1280SP 80TMU 32ROPs 256Bit 2GB GDDR5
1000/6000MHz 130W
浮点性能: 2.56TFlops
US229 1599元
vs HD7870 +15%
Source (use Google Translate)
What do you guys think? If any of this is credible it looks like the Titan will have some competition soon...
Old May 28, 2013, 03:50 PM
I thought they were skipping 8 and leaving that for mobile/oem, while going straight to 9. Much like the GTX 300 series.
Old May 28, 2013, 04:17 PM
tangrisser's Avatar
It looks like it's a rebadge of 7xxx series to please OEM. I think AMD could gain another 5 - 10% gain on Radeon 7xxx hardware if they could improve driver.
Check out my SALE page
Old May 28, 2013, 06:27 PM
hero1's Avatar
Smile
The can rework the PCB to make a better card and relase it as HD8000. I hope they do so Nvidia doesn't have the monopoly to itself.
I don't know if the source is credible but time will tell.
Old May 29, 2013, 06:12 AM
The 8870 and the 8950 look very similar to each other. I am not sure if these are accurate. They have all most same spec, +100 on the core, +1000 on the memory and 2GB more of memory. From what I have read the flagship cards are called Venus and there bring back the old XTX HD, XT, and HD Pro branding.
This chart looks as close as we are going to get till they release them.
Old May 29, 2013, 07:47 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Oland is not a next gen part part. At least it better not be since it is based on current architecture.
Old May 29, 2013, 08:49 AM
Sushi Warrior's Avatar
Oland is FAR lower end than 8850... Think 8570 or 8450. And yes it is GCN 1.0. The source is entirely wrong...
Old June 3, 2013, 04:07 PM
Warcrimes's Avatar
I'd like to see what the numbers for the 8970 are. But if ther rumers are true about a 35% boost over the 7970 then i might think Nvidia might be in trouble. i do hope they fix the Xfire suttering issues.
Gigabyte GTX 780 WindForce OC 3 GB Review | techPowerUp
Old June 3, 2013, 04:22 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
I would love to see AMD get a 35% boost. That would be so awesome for consumers. Right now if you want ultra high end...its NV (titan). Want high end...its NV(780). Its only midgrade that you see competition (770 vs GHz edition) This is not a good thing. :(
Old June 3, 2013, 05:57 PM
35%? I think they've got more than that in the works
Which gpu is be better for my specs? Justin Papp Video Cards 14 March 15, 2013 09:58 AM
Further Speculative specs on Radeon 7 series cards terrybear Rumor Mill 2 September 14, 2011 09:44 AM
memtest RAM specs vs. manufacturer specs LaughingCrow RAM 4 January 11, 2011 03:43 PM
ATI Radeon HD 5830 Specs and Cards Leaked FiXT Press Releases & Tech News 11 February 27, 2010 10:25 AM
Radeon 4850 briefly on sale, more specs revealed 200 bucks! belgolas Press Releases & Tech News 0 June 14, 2008 07:26 AM
