Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Closed Thread
  #21 (permalink)
Old September 24, 2013, 04:13 PM
IRQ Conflict's Avatar
Originally Posted by trodas View Post
Well, educate yourself!
Yeah, I did search and read about it. Seems like a lot of game devs and Futuremark people are/were on board with this scheme. What to do? No one seems willing to call them on it.
  #22 (permalink)
Old September 24, 2013, 04:32 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Remember this word: Mantle.
It'll supposedly be a game changer.
  #23 (permalink)
Old September 24, 2013, 04:37 PM
Heh, I'm not sure the reference to extreme heat/pressure is a good thing (TM).
Hope all is well for you Sky. Have a great time buddy!
  #24 (permalink)
Old September 25, 2013, 01:19 AM
trodas's Avatar
Red face
Delavan -
I'd like to score 4GB cards...
I did not see the point of having so much memory on videocard. Most of the time it will be used like 5% or 10% of it? There are recently some czech benchmark that compared how the more memory (and a bit higher clocked Sapphire) card compare to one that has less videomemory.
Test Sapphire Radeon HD 7790 2GB OC - Recenze
So they are comparing a Sapphire Radeon HD 7790 OC 2GB to MSI R7790-1GD5 - in other words, 2G videoram to 1G of videoram. And you does not have to know Czech or use Google translator to understand this result:
Test Sapphire Radeon HD 7790 2GB OC - Crysis 2 (DX11) | Diit
To put it short, except a Ultra settings (probably due to the extreme level of tesselation flying around) where the cards are even, the MSI was actually FASTER in all tests. Yes, by one frame only, but it was faster with "only" 1G of videomemory compared to the 2G of memory.
And not only that - the Sapphire card was OC a bit:
Sapphire - core: 1050MHz, videoram: 6.4GHz
MSI - core: 1000MHz, videoram: 6.0GHz
So, in real gaming scenario, a higher clocked card with 2G of ram is slower, that 1G card...
They commended it this way:
A hned na úvod první paradox. Výkon je velmi nepatrně nižší než u 1GB HD 7790 s referenčními takty (MSI). Opakovali jsme ta měření 3×, pokaždé se stejným výsledkem. Měřeno na stejných ovladačích, ve stejný týden. Vysvětlením je buď nějaká paranormální síla, PEBKAC, nebo prostě míra tolerance přesnosti měření.
And right at the start we have first paradox. The speed it slightly lower that with 1GB HD 7790 with reference clocks (MSI). We repeated the measuring there times, each time with same result. We measured at the same drivers, in the same weekend. Explaination for this could be either some paranormal force, PEBKAC or just the measuring tolerance.
It is good to note, that results in Stalker: Call of Pripyat (DX11) are 21.25 vs 21.75 fps at maximum settings FOR the 2G Sapphire (66.25 vs 68.75 at middle settings for Sapphire) and one (hi setting) and two frames (56 to 58) gained on Deus Ex 3 (DX11 + teselace) test. Also one frame is gained on Need for Speed Shift 2 Unleashed, 2560×1440 test - 31 to 32fps.
So, as you can see, even with "low memory" videocard, uping the memory size to 2x could not yield anything significant at all. I would be inclined to say that everything is well into the error tolerance of measuring and the Crysis 2 example just fuel the speculations about what the hell the game do on AMD cards. By all means, the 50MHz on the core (this is minimal) and more importantly the 400MHz on the rams gotta show up somewhere, not to mention double the size of the ram.
But it is not showing anywhere, therefore either:
- the Sapphire used worser timings of the rams that MSI, hence the slow-down
(but this is disproved by the little yet measurable speed-up of other games, where the results are consistent)
- Crysis 2 engine purposedfully slown things down when detecting more ram on AMD by doing something bad
(for the precedent with the tesselation and with all the cheats before I think this would be the best bet)
Yet all it all, no performance gain from 1G to 2G (as all these gains can be attributed to the slightly higher clocks). So what good 4G could be for? Sure thing, some hugry games would take them gladly in the future, but ATM not even FarCry 3 or BF4 is IMHO going to benefit from the 4G of videoram.
While they sure will benefit from each Mhz UP for the CPU/GPU/ram/videoram clocks.
Delavan -
BF4 benchies will be MY milestone to pick my next upgrade!
I liked playing BF2, oh, well, good times Now I just like to have a AGP card working in AGP regime and not falling back to PCI one All I can say on BF4 is just "wow"... Watching some of the game videos (albeit I have to watch them in low-res because of the card/mobo troubles) and they are amazing to say at least. The Siege of Shanghai was jaw dropping - traping the tank by shooting the support culum? Many things are destructable? Oh my...
"It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
"I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway :) my config - my caps
  #25 (permalink)
Old September 25, 2013, 01:20 AM
Dzzope's Avatar
Just hope it's not as big, hot or load as a volcano once it ramps up...
Trodas:
Totally depends on the games, res, detail level, if you use custom textures etc etc.. my Vram goes from 1.2GB to 2.2 pretty easily in the same game (@1440 res)
Random quotes:
AKG: "So please don't piss on people and claim its raining. "
Soullessone21: "Their the only fat bitches I ever want in my wife :)"
DeeraxTheCoolNemo: "I never preSs CaPLoCK I just HiT my keyS so Hard ThEY Crit"
  #26 (permalink)
Old September 25, 2013, 02:57 AM
That is correct. Also, in general the more ram you stuff on a board the looser the timings. And in some cases the slower the ram is. It used to be a much bigger advantage than that years ago. I saw similar tests where another card of the same type could be as much as 10 FPS slower than the one with half as much ram.
The kicker (as I later learned) was that the card that had more ram had a much longer shelf life due to the fact it had more ram. Yes, I saved a buck by going 256Mb's rather than 512. Was it worth it? Not for me. The amount of ram was never intended to speed up the GPU. Rather, enable higher resolutions and textures.
Nothing has changed, though, the new direction the Xbox is taking with regards to memory usage and textures may prove interesting. Only time will tell. Until then though, I would recommend as much ram as possible withing reason of course. If your GPU is not capable of running those extremes the extra memory probably won't do you much good.
For example, I wouldn't recommend going over 2 GB's on anything less than a 7970 (preferably two). or 670 in SLI running 3D or extreme resolutions. Basically, if your GPU(s) won't run 30+ FPS in a given scenario the amount of ram won't do you squat.
  #27 (permalink)
Old September 25, 2013, 10:15 AM
SKYMTL's Avatar
Remember guys: Live Stream in a few hours!
  #28 (permalink)
Old September 25, 2013, 10:22 AM
great_big_abyss's Avatar
Alas...I'm at work...so no live streaming for me..
Wait...I can stream from my phone YES! I am saved!
  #29 (permalink)
Old September 25, 2013, 10:24 AM
mattlef's Avatar
Mantle?
Without breaking NDA can you elaborate?
CC-HotSpot Host
YouTube Instagram Twitter
  #30 (permalink)
Old September 25, 2013, 10:28 AM
SugarJ's Avatar
If he could say more he would.
Live stream on AMD's Youtube channel here: https://www.youtube.com/amd 3PM Eastern, 12PM Pacific
Closed Thread
Vancouver Island...really? JD Off Topic 12 July 10, 2012 10:32 AM
[WTB] 775 C2D or better on Vancouver Island Soullessone21 Buy/Sell & Trade 4 May 12, 2012 07:37 PM
Dead Island Deeival Gaming 81 January 26, 2012 03:35 PM
Upcoming NVIDIA Cards: HWC Announcement SKYMTL Video Cards 82 March 26, 2010 04:01 PM
Ramea Island Pics cmac79 Off Topic 4 August 17, 2009 08:40 AM
