Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old February 15, 2013, 09:47 PM
Soullessone21's Avatar
Default ...AMD 8xxx series compatible but there is not 8xxx yet odd
ARCTIC
looking at a LCD mount and came across their compatible lists :S
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old February 15, 2013, 09:59 PM
Soultribunal's Avatar
More than likely because the 8XXX will be revamps of the original 7XXX series just refined.
My thoughts,
-ST
www.realhardwarereviews.com
Old February 15, 2013, 10:05 PM
IRQ Conflict's Avatar
Methinks they jumped the gun.
Old February 16, 2013, 01:41 AM
Dzzope's Avatar
Whatever about the compatibility I'd love to see a review of these. :D
Old February 16, 2013, 06:25 AM
GT7R's Avatar
That means they know the 8xxx will use the same base core and PCB, just slightly tweaked. And from a customers POV it's nice to know that you van buy the cooler for your current card and possibly re-use it when he decides to upgrade.
Old February 16, 2013, 01:10 PM
Killswitch's Avatar
This is why........... AMD Radeon? HD 8000 Series Graphics (OEM)
OEM 8000 series cards are the 7000 series rebadged.
Radeon HD 8000 Series Goes OEM as AMD Rebrands HD 7000 Desktop GPUs | Hardware Canucks
I bet the naming of AMD's next gen cards will change because of this in an attempt to avoid confusion.
Old February 19, 2013, 02:43 PM
tangrisser's Avatar
I was hoping that they would at least make some sort of improvement like more efficiently running cores, higher clock, etc etc.
Even GTX Titan rumour-ish news sounds better than this.
Check out my SALE page
Will all of this be compatible? ShadowRocks New Builds 23 February 15, 2013 01:39 PM
Compatible? Deano85 CPU's and Motherboards 2 November 19, 2011 08:49 AM
In need of a PS3 compatible headset. Dar_ell Peripherals 3 August 16, 2010 01:13 PM
Will my mobo be compatible? Shiverwarp RAM 1 July 19, 2007 04:14 AM
Help! old floppy compatible??? Babrbarossa CPU's and Motherboards 7 December 17, 2006 12:58 AM
