Originally Posted by JJThomp Well bulldozer clocks are looking pretty good... Apparently some guys was able to push his engineering sample to 5.5ghz on air (in the stepping that AMD said wasn't good enough I think B1), but correct me if I'm wrong released samples should go even further considering they are actually complete. |
From what I remember, the problem was not with clock speeds of the Bulldozer Eng Sample but in the wattage. The samples they used were running at 186W, while the final products should be in the 120-140W range (for the high end ones) - also I belelive the CPU voltage of the BDz ES was overly high at default settings, nevermind when they had them OC'ed.
Personally, I am not concerned about the oc'ing abilities of either SB-E or BDz, but more price to performance (in workstation environments). Hopefully, AMD will release at least their Opterons on time to give Intel some competion before the SB-E Xeons come out.
