Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old March 13, 2011, 09:02 PM
Default Rumor: GTX 590 has downclocked 580 cores
Here's the link, for those who are interested.
Basically saying that the core speeds will be dropped down to 600mhz core and 3400mhz memory from the default 772/4008. Not sure if it's a reliable source though...
Old March 13, 2011, 10:35 PM
on water there should be no issues, or with custom triple slot coolers from the different partners
will the circuitry on the pcb take gtx580 frequencies? that is the question. the evga hydro version should
be interesting, to say the least
Old March 13, 2011, 11:45 PM
GT7R's Avatar
580's run less hot than 6970's, so I don't see any problems with a pretty standard cooler.
Old March 14, 2011, 12:26 AM
artistpavel's Avatar
That downclock is acceptable to me, I won't overclock or anything.
Old March 14, 2011, 01:10 AM
I've got two issues with the 590...
It should easily beat the 6990 if it uses a TDP of 375w, but SLI 580s at those specs don't really push the limits of the 6990 hard enough to make the 590 a clear winner (which it should be as the 580 has a lower TDP than the 6970 and better performance).
The second issue is how they are going to price this card as they won't want to be too aggressive against the pricing of the 580 SLI, but need to be competitive with $700 MSRP.
Will they just have very low stock of the 590 to ensure people keep buying 580s?
Old March 14, 2011, 08:33 AM
I looked at some thermal imaging and the 580's were definately much hotter.
Old March 14, 2011, 01:34 PM
rapmaster's Avatar
GeForce GTX 590 Key Features Revealed | techPowerUp
More info, the 590 will cost more than the 6990 for sure.
Quando omni flunkus moritati
Old March 14, 2011, 02:11 PM
3gb of ram probably means 2x580 cores.
I'm glad Nvidia didn't use a blower fan like AMD did, I've been considering one for a folding box and a blower would be way too loud. You're exhausting inside the case anyhow, blower fans are a stupid idea.
Old March 14, 2011, 02:19 PM
from the slide thingie that one will output in the case as well. fail on both parts /;p
Old March 14, 2011, 03:24 PM
If this is true then it is a pretty substantial drop in performance per core compared to a full out 580. We seem to be reaching the current thermal/power limits of single graphics cards with the 6990 and "gtx 590". I think we need a die shrink or 2 to get power consumption back in check (not that some of you care at all).
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
GTX 580 Backplates ! rjbarker Video Cards 35 January 5, 2011 09:15 PM
Rumor of GTX 570 and GTX 560 on its way vohiep84 Rumor Mill 15 November 20, 2010 07:43 AM
Rumor of GTX 680 on its way in the future! belgolas Rumor Mill 5 November 14, 2010 11:47 AM
Rumor Report: NVIDIA Designing a GTX 460 FiXT Press Releases & Tech News 10 April 8, 2010 06:55 PM
