Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
  #101 (permalink)
Old March 22, 2011, 07:54 PM
Delavan's Avatar
and for the price, lets see if people go for it or dual 570's ;)
I'm not too impressed by the 570 after all that jazz about weak power stages (4 phases)...
I know most of the customers with "fried" 570s did disable the OCP and increased the voltage...but it would have been nice to be able to fully rely on those..seems like they're weak in the knees....
I guess they're fine at stock clocks/volts/OCP on...
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
  #102 (permalink)
Old March 22, 2011, 08:12 PM
Soultribunal's Avatar
Any card where you push the voltage past design spec you are going to risk killing. So the fact that disabling a protection circut on a card fries it, is well, tough luck. Its there for a reason.
ST
www.realhardwarereviews.com
  #103 (permalink)
Old March 23, 2011, 01:49 AM
GT7R's Avatar
Originally Posted by mkultra View Post
som1 correct me if i'm wrong but gpuz show bw for 1 gpu at a time, so that's x2
True.
  #104 (permalink)
Old March 23, 2011, 03:54 AM
ST
the 570 is abnormally weak on the power side for a gfx of that performance
  #105 (permalink)
Old March 23, 2011, 03:45 PM
Nvidia drops GTX 590 pricing
... Oh Fudzilla... sigh... really?
  #106 (permalink)
Old March 23, 2011, 04:09 PM
700$ in the US makes much more sense
  #107 (permalink)
Old March 23, 2011, 05:16 PM
Do you have something I can read that is more concrete on the matter? I'm curious to see what is weak, it has a solid power distribution system from what was initially seen.
ST
  #108 (permalink)
Old March 23, 2011, 06:32 PM
core's vrms are weak, idk what's different from the 560 and 580 but they are more affected that the others
nothing concrete, but too much "coincidence", maybe it was just a bad first batch it seems to have settled in, but still you don't see that many 580 dead for no obvious reasons
dead 570 report
User: xxbassplayerxx
Core Voltage: 1.212V (1.223 with DMM)
Clocks: 1100/1200
OCP/Power limit disabled: No
Load Temperature: -40C
VRM Cooling: Stock unisink / cold from phase / fan
What you were doing: Running Vantage Performance
User: jonjryjo
Core Voltage: 1.1v
Clocks:900/1800/2100
OCP/Power limit disabled: Yes via /GTX500OCP gpu-z argument.
Load Temperature: 58*C, it never went above 45 with power limit enabled.
VRM Cooling: DDGTX580
What you were doing: OCCT
User: slickric21
Core Voltage: 1.05
Clocks: 880/2000
OCP/Power limit disabled: Yes, via GPUZ 1.5.1 & /GTX500OCP
Load Temperature: 44'C
VRM Cooling: Accelero Xtreme VR sinks (+2 extra 120mm fans blowing on them)
What you were doing: OCCT GPU, full screen/complexity 8.
User: kerrk
Core Voltage: 1.2v
Clocks: 920/1840/2200
Load Temperature: 70 C
VRM Cooling: Stock
What you were doing: Benchmarking with 3dMark 11
User: rancor
Core Voltage:1.100(After burner)1.034 GPU-Z
Clocks:875/1750/2000
OCP/Power limit disabled: Yes (Hit 105A in GPU-Z)
Load Temperature: 80
VRM Cooling: Stock
What you were doing: Furmark stress testing
User: mistkron
Core Voltage: 1.100
Clocks: 900/1800/2000
Load Temperature:
VRM Cooling: Twin Frozr II Unisink
What you were doing: Unigine Heaven
User: Shredicus
Core Voltage: Unlocked to 1.2v was around 1.17 at the time
Clocks: 980/2200 - 920/2000
Load Temperature: 70c
VRM Cooling: Stock
What you were doing: Crysis
User: miahallen
Core Voltage: 1.2V via MSI AB v
Clocks: 950/2200
Load Temperature: ??? (fan @ 85%)
VRM Cooling: Stock
What you were doing: 3DMark Vantage
User: miahallen
Core Voltage: 1.15V via MSI AB v
Clocks: 1000/2250
VRM Cooling: Stock
What you were doing: 3DMark 06
User: Mean Machine
Core Voltage: Stock
Clocks: 780/1050
Load Temperature: Barely did load it at all
VRM Cooling: Stock
What you were doing: Nothing. Just decided to kill itself. Did use it for our review though, where I did run Vantage at 885/1160 maybe once or twice, since then it was left at stock voltages and 780/1050 for some CUDA rendering stuff. It isn't a total meltdown though, just doesn't do stock frequencies, i.e. useless nowadays.
user:elgappo
Mines dead as a dodo now also.... Died at stock everything, palit sonic platinum, not even reference...
now let's get back to the 590, not even a day before launch
Where to buy XSPC 5.25 Bay Dual Res, Dual DDC Pump Kartner Water Cooling 11 July 1, 2010 09:14 AM
EOL GTX470 and dual GPU Fermi soon??? Delavan Rumor Mill 10 June 9, 2010 07:34 AM
Galaxy Out to Impress at Computex; Dual-GPU Fermi and More mikellini Press Releases & Tech News 12 June 8, 2010 05:16 PM
xspc dual bay dual ddc pump resivour gomer Water Cooling 12 May 10, 2010 04:00 PM
More problem with Fermi [SA] MarkOne Rumor Mill 29 March 13, 2010 09:46 PM
