Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old January 16, 2011, 02:39 PM
Amarthfea's Avatar
Default HD 6990 early as second half of feb [Rumor]
After the demolishing news at Christmas time of the delayed card, I've been searching for a while to find a new time to kind of set my eyes towards. Not that I can afford it anyway, but I enjoy seeing the benchmarks
So according to both fudzilla, and softpedia, the HD 6990 should be out for the second half of February, however it may possibly slip into early march (I think that it will be almost mid march before there will be any stock available though). The delay being from the Chinese New Year, which I don't find overly surprising.
Also there are rumors that they are working on a new card with twin barts cores, a change from the cayman cores that are supposed to be used in the HD 6990. From my understanding though wouldn't this just add a more affordable dual gpu card to the lineup?
- adam
~Elysium, I behold your beauty...
Old January 16, 2011, 02:51 PM
ern88's Avatar
I wonder how it will compare to the Nvidia 580 GTX
Old January 16, 2011, 03:11 PM
Soultribunal's Avatar
If they are switching from Cayman to Barts its possible because the temps or Power consumption is too high for cayman.
Should be interesting to see what they bring out, and what nVidia responds with. Something tells me though that nVidia has learned from its past and maybe will get their dual GPU card out first.
ST
Old January 16, 2011, 03:19 PM
Delavan's Avatar
Like Soultribunal mentioned, that new card could just be that they cannot fit two caymans on the same card for power management reasons....
There will be only ONE AMD dual GPU card. We all hope it's a dual Cayman. If it's dual Barts, it wont live to the 5970's reputation and longevity...
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old January 16, 2011, 06:06 PM
ZZLEE's Avatar
Evga had deul cores at CES so Nividia defitly in the works.
YouTube - EVGA Shows off New Dual-GPU Video Card at CES 2011 - GeForce GTX 560?
edit EVGA on there own (Not a Nividia )
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 17, 2011, 04:57 AM
Amarthfea's Avatar
Oh snap, if it is only one dual gpu card, and we use barts core its definitely going to be a disappointment, with all the anticipation build up from the delays. I'm not saying the card will be bad but I don't think in any way will it be able to hold out to the dual gpu nvidia (we all know it's on the way).
maybe i'll have to stop being such a fanboy and just go with nvidia for my next card..
Old January 21, 2011, 08:41 PM
Delavan's Avatar
Pictures of the 6990???
Posted on anand's site:
Amd HD 6990 Photo's - AnandTech Forums
Big card! You can see the two x-braces on the back...also, the fan seems to be in the middle...it might just be a prototype with a blank PCB who knows.
Old January 21, 2011, 08:49 PM
CMetaphor's Avatar
Quadfather
Not sure if thats legit and/or the final version yet. And Ill explain why I think that:
Look at the position of the X-braces on the card. The second GPU core is almost at the very edge of the card, which means the VRMS/GDDR is in between both GPU cores? This means either AMD is breaking from standard and putting in a central fan, which will exhaust the heat of the first GPU core outside the case and exaust the second back into the case. I don't find this very likely, but it is possible.
HOWEVER!!! Upon some further thought, and perhaps my over-optimistic hopes for Antilles, this Could be a legit card with the cores/GDDR configuration as above... but it created as such on purpose due to AMD having (finally?) developped a direct interconnect between the GPUs... OR at very least a way for them both the share the same GDDR.
Food for thought?
Old January 21, 2011, 09:27 PM
all i can say is that the pcb high rez pictures might make some lol, and others awe :)
from that far looks like a decent es, hell if they slap a sticker on it it could be the final product.
for the love of god, someone implement fan control on unknown cards plz
Old January 22, 2011, 05:25 AM
Amarthfea's Avatar
haha they are just trying to build something bigger than the ARES. I wonder which one has more copper in it?
Who's waiting for 6990? Or gave up and bought 2x 6970s? CMetaphor Video Cards 8 January 17, 2011 06:51 AM
Radeon 6990 Rumor [Bulletblips] ZZLEE Reviews & Articles from the Web 9 December 24, 2010 05:41 PM
Eventual HD 6990 cooler? Or fantasy? Delavan Rumor Mill 17 November 8, 2010 05:28 AM
New build @Feb. 15, 2010 curry New Builds 4 January 26, 2010 03:08 PM
half hight vid card with half hight back plate tzetsin Video Cards 11 June 17, 2009 08:00 PM
