<~----> A preview of two Cooler Master 2011 fans - Hardware Canucks
Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old December 1, 2010, 02:48 PM
CM MR HAF's Avatar
Cooler Master USA
Default A preview of two Cooler Master 2011 fans
Turbine Master:
Cooler Master has a 16 blade design with semi/enclosed frame allows for lower RPM with higher CFM. This means better low speed performance without high noise associated with traditional high RPM/high pressure fans. The 800 and 1200 speed versions are recommended for near quiet chassis. An semi open frame allows more airflow and minimizes turbulent sounds.
Note if you install the 1800 RPM version on the Hyper 212+ this is what it will look like
Specifications are below:
  • Turbine Master Mach .8: 800 RPM, 35.07 CFM, 13.83 dBA, 0.08A current
  • Turbine Master Mach 1.2: 1200RPM, 56.5 CFM, 21.1 dBA, 0.19A current
  • Turbine Master Mach 1.8: 1800RPM, 80.3 CFM, 30.5 dBA, 0.38A current
Xtraflow PWM:
More information soon
Cooler Master - CM Storm - Choiix
Old December 1, 2010, 03:14 PM
CMetaphor's Avatar
Quadfather
Now thats just dam cool! Can't way to try one of these out! I guess one can't use two of these in a push-pull though, due to the open frame? I cant quite tell from the pictures if the four mounts go above the level of the "cone" of the fan or not, but im guessing no :P
Old December 1, 2010, 03:17 PM
AkG's Avatar
AkG AkG is online now
Hardware Canucks Reviewer
What bearings are going to be in these beautiful bad boys? Hope its FDB!....and not 2B and definitely not 1B1S or sleeved. :)
Old December 1, 2010, 03:19 PM
very nice. what kind of pricing should one expect, and hows the air pressure figures? :)
going back to the hyper cooler, is there a newer version coming out as well?
Old December 1, 2010, 03:37 PM
Supergrover's Avatar
The engine uses technology Barometric Ball Bearing
Like the ability to remove the blades from the housing.
More info Below
Google Translate
R.I.P.
Old December 1, 2010, 03:46 PM
AkG's Avatar
Ah so basically a newer fancier version of their Excalibur line (BBB bearings, removable fan, etc)! That wont be too bad....though, too bad about about the ball bearing design...fancy name or not a ball bearing design is a ball bearing design...even if they make the ball bearings from dif material than normal.
Was REALLY hoping they would have gone FDB :(
Old December 1, 2010, 04:13 PM
CM MR HAF's Avatar
Cooler Master USA
FDB technology are only available through patent holders, one of them being Sony and there are three others. CM is not a patent holder for that yet. We do have Dynaloop which is semi FDB technology available on our Xtraflo fans that are on our V6 series.
Old December 1, 2010, 04:56 PM
Looks sweet! Now for me to finally put my 212+ in a push/pull config, lol.
Old December 2, 2010, 11:55 AM
Bao Bao is offline
I'm up for 5 of those 800 rpm fans :)
Old December 2, 2010, 12:15 PM
Soultribunal's Avatar
By chance do you know how much static pressure these output?
I can see them as being somewhat useful however without a massive amount of pressure like the R4's have, they might be less than ideal for Heatsink, Radiator Work.
Not saying I don't like them, just wondering how to apply them.
ST
Tags
cooler master , hyper 212 plus
Project X: Redemption! (May 13-15,2011 Calgary) Project X Canadian LAN Parties & Events 11 May 11, 2011 05:47 PM
LANified! 8: Nuclear Launch Detected Calgary Jan 22-23 2011 BloodyIron Canadian LAN Parties & Events 10 February 2, 2011 07:04 PM
3D marks 2011 delayed Ryoohki Gaming 0 November 29, 2010 04:06 PM
2011 Hockey Pool? Deeival Hockey 2 November 21, 2010 03:34 PM
2011 NHL outdoor games Eldonko Hockey 8 May 28, 2010 02:37 PM
