Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old November 7, 2010, 04:38 PM
Soultribunal's Avatar
Originally Posted by lowfat View Post
Maybe I am missing something but squirrel cage blowers don't work like that. Blowers don't pull air from one side and through it out the sides. It needs a hole out the side to pull the air in.
If you notice though Lowfat, the fan blades are hooked a bit , so it actually gas some merit. And with the blades coming so close to a side wall on the bottom part it will help the system work as well.
Looks good.
ST
www.realhardwarereviews.com
Old November 7, 2010, 07:04 PM
CMetaphor's Avatar
Quadfather
Originally Posted by kruzn4evr View Post
Better have a good case intake fan pulling in LOTS of cool air for that Xfire setup.
Actually, this method will work far better for an Xfire setup, since neither card will be fighting the other for air.
Originally Posted by Keltron 3030 View Post
i question this design. with the fan after the heatsink, adding dust to the equation will not be a good result. sure, a good spray of compressed air will help getting most of it out, but what if ou get that caked on stuff?
I'd MUCH rather have dust on the fins of a heatsink than on every single blade of a blower fan (which is dam near impossible to clean btw).
Originally Posted by martin_metal_88 View Post
Damn this is nice and looking sweet but, if the fan is hidden like that won't it be noisier? Let wait for the real one and see what AMD can give us:)
I agree that we should wait, but also having the fan in the "middle" like this should help block some of the noise, rather than amplify it, which should allow it to run harder to keep the dual GPUs cool. This is all just guesswork for now though...
Such fans can work in any direction really, some even use a 90 degree turn and still work (like some vaccums and industrial ventilation systems). I see no reason why this wouldnt work.
Old November 7, 2010, 07:33 PM
martin_metal_88's Avatar
H was not talking about noise from the fan itself but sincehe suck air turbulence could be an issue. But well, as we both agree, only time will tell us. Maybe AMD have a design that will blow our head with this ( if it's true for sure )
Old November 7, 2010, 07:51 PM
JD JD is offline
As per the video: "GPU Cooling and Design by Daniel1z" so obviously just a designer's ideas on what it could look like. Surely an interesting concept, but unlikely what ATI/AMD will be using.
Same things are done with concept vehicles for various brands. Artists that are not associated with the company will produce various designs/ideas that they consider fitting to that company.
Old November 7, 2010, 10:24 PM
Polygon's Avatar
Well, it sure is sexy that's for sure. Interesting concept.
'Do not wish for easier lives, wish to be stronger men'
Old November 7, 2010, 11:19 PM
+ you wont risk getting something in the fan and borking/stopping it anymore :) again, i think two will do better on a big dual card like that
Old November 8, 2010, 05:45 AM
CMetaphor's Avatar
Quadfather
That's not possible: a 5970 is already a foot long and cant fit in some cases - there is no room for two fans and sufficiently large heatsinks to allow for two fans unless they make it a 3 slot card or (something I'd like to see) a taller card. Time will tell though....
Old November 8, 2010, 06:28 AM
Actually CM, they could put a Cross Blower VS what you see in the pictures there and that would provide enough room to probably put two in safely.
That being said, it is doubtful they will ever go that route.
ST
Final Fantasy XIV open beta headsh0t Gaming 30 September 10, 2010 04:48 PM
All fans of Monty Oum ( Dead Fantasy ) and Red VS Blue come here. EPIC!!!! Digikid Off Topic 5 June 27, 2010 09:58 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
OverClockers Fantasy Football 07/08 3oh6 Off Topic 5 August 23, 2007 01:57 PM
Strategy Informer reviews Final Fantasy XII Supergrover Reviews & Articles from the Web 0 February 27, 2007 10:45 AM
