Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
Old August 11, 2010, 01:33 AM
CM MR HAF's Avatar
Cooler Master USA
Originally Posted by _dangtx_ View Post
unfortunately it looks so. like with the 430, it makes it look...how should i put it? a lesser part.
ps04/05 if you dont have a large arse card start looking more and more 'better' as a value case
Not to be a contrarian, but this leak is not the HAF 912.
Cooler Master - CM Storm - Choiix
Old August 11, 2010, 02:17 AM
long gpu support, and no window would please many.
Old August 11, 2010, 02:54 AM
Jackquelegs's Avatar
Shock of the day +1
Could you leak the proper ones then
Iapetos
Zephyranthes
Old August 11, 2010, 04:00 AM
At 60$ this case would be damn could, and surely would be my next case, at least before something better is released -.- I'm not a huge fan of HAF design, but it's all about their features that I like.
Old August 11, 2010, 05:41 AM
JD JD is offline
Well whoever photoshopped this together did a pretty decent job. Hopefully the real one ends up being similar...
Old August 11, 2010, 05:46 AM
fishingfanatic's Avatar
Smile Rumour Mill
Interesting look. I agree that the side window should go. Like the rest of the HAF series cases, their cooling thru high air flow makes them a viable option. Of course the price is reasonable with many of the features of its larger bretheren, which I happen to like.
HAF 912 CM MR HAF Rumor Mill 45 August 27, 2010 10:41 PM
Coolermaster CM 690II Advanced Charmster Cases 2 June 18, 2010 10:55 AM
Kovok's New CM 690 II Advanced Kovok Case Mods, Worklog & Gallery 23 March 13, 2010 11:57 PM
CM 690 Advanced II Vdub90 Cases 15 February 18, 2010 01:51 PM
Operation HAF Baked! Cooler Master HAF 932 Lithotech Case Mods, Worklog & Gallery 42 December 17, 2008 10:22 AM
