-   Rumor Mill (http://www.hardwarecanucks.com/forum/rumor-mill/)
-   -   AMD 12 cores (http://www.hardwarecanucks.com/forum/rumor-mill/30199-amd-12-cores.html)
Wi-Fuzzy March 23, 2010 07:43 AM
AMD 12 cores
This could be a CPU that makes the folders that bought the 6 core i7 wonder if they did the right thing. Fudzilla
CMetaphor March 23, 2010 07:49 AM
It ain't exactly cheap :haha:. Whole new platform: G34 socket, quad-channel DDR3, etc etc. But still, very nice procs, although if I'm not mistakne the 6000-series is for multi-sockets whereas the 4000-series will be for single or dual socket applications.
The procs themselves are huge too!
http://blogs.amd.com/work/wp-content...IMG_0296-2.jpg
Apparently G34 is has 1944 pins/pads! Sweet Jesus! :shok:
MarkOne March 23, 2010 07:58 AM
X12 6164 runs at 1.7GHz
X12 6176 is clocked at 2.3GHz
with the actual folding client, you can use only 8 cores, and at those speed you will never finish the work on time.
matsta31 March 23, 2010 08:05 AM
Just a little correction, you can use more than 8 cores for folding, but not on a window based machine. An all Linux rig will work.
_dangtx_ March 23, 2010 08:22 AM
what is actually a wonder is the power envelope..65 watts for a 12 core that doesnt run at 5mhz? whohoo!!!
Wi-Fuzzy March 23, 2010 10:52 AM
This would chew up -bigadv work units. An i7 920-965 would perform like 5.7 ish cores (hyper threaded is not the same as physical cores) The i7 980 would probably be about a little over 8 cores in the real world. The AMD may be down on mhz...but would have about 4 extra cores...performance wise. I hope that made sense....?
MarkOne March 23, 2010 11:00 AM
let's do the match
let's say the 7-980 run the equivalent of 8 cores at 4,5 ghz so that make 36 put the 12 core of the AMD at 2,3 it's make 27,6 , because for OC your 12 core , you need a board, and this is a server CPU, so no OC
chrisk March 23, 2010 11:35 AM
As mentioned, you would need to run native Linux (no vmware) to run more than 8 cores.
At those power levels though, I would be really interested in seeing how much PPD/power one of these CPUs produced and needed with all 12 cores unleashed.
The clock speeds are a little slow, and I don't know anything about Opteron OC. I wonder ow the 1.7GHZ 12 core would stand up to a 4GHZ HT 8 core in PPD?
Wi-Fuzzy March 23, 2010 11:54 AM
Originally Posted by MarkOne (Post 352297)
let's do the match
LOL...after 4.5 ghz of 24/7 overclock...for say 6 months, we can have a conversation about which one is running. I think your overclock estimate may be a little optimistic..to say the least. It may pass benchmarks....but 24/7 %100 cpu usage is another thing alltogether.
MarkOne March 23, 2010 12:33 PM
it's a special chips, as CM say, it need a new socket and probably chipset too, so I dough that will be an option in the bios to oc this beast ,
Originally Posted by Wi-Fuzzy (Post 352328)
LOL...after 4.5 ghz of 24/7 overclock...for say 6 months,.
I will have no problem to run the cpu at 4,5 ghz for 6 months, Lowfat do better with a 920.
and before someone told me I'm a Intel fan boy, I just reply to this
"This could be a CPU that makes the folders that bought the 6 core i7 wonder if they did the right thing."
