Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
  #21 (permalink)
Old November 22, 2009, 11:39 PM
Originally Posted by MpG View Post
My bad, I stand corrected on the 8-pin power draw. But I'm fairly certain that the PCI-E specs do dictate how much power can be drawn by the device, according to what connectors are attached to the device. It doesn't encompass the area of chassis/board/supply testing, so the onus is on those designers to make sure their products can supply what they're supposed to.
I believe the 300W number comes from assuming 75W from the slot, plus the additional power provided by the 6 and 8-pin connectors.
The 300W number does come from assuming 75W from the slot, since it's based on backwards compatibility with PCI-E 1.x. However, there is no specification for the maximum amount of power that a card can draw. There is only the ATX spec which dictates how much power can be supplied by each connector, and the PCI-E spec which dictates how much power can be supplied by the slot itself.
  #22 (permalink)
Old November 23, 2009, 05:37 AM
Sushi Warrior's Avatar
Regardless of whether or not it will be possible to power it (which they can), the major issues are heat and power consumption.
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
  #23 (permalink)
Old November 23, 2009, 05:51 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
They have already stated that the cooler on the HD 5970 is rated up to 400W of thermal dissipation.
  #24 (permalink)
Old November 23, 2009, 04:49 PM
That's still pushing it, you start getting heat problems at that point.... and ATI probably doesn't want another card with heat problems.... bad press.
  #25 (permalink)
Old November 23, 2009, 05:20 PM
And what do you think qualifies as a "heat problem"?
  #26 (permalink)
Old November 23, 2009, 05:55 PM
belgolas's Avatar
I don't know but you can only pump so much power through a small area before even water cooling can handle. Graphics cards are already really hot and it is easy to get a GPU to a 100c.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
  #27 (permalink)
Old November 23, 2009, 06:04 PM
If the cooling is designed to handle 400W, I don't see why there would be any problem.
  #28 (permalink)
Old November 23, 2009, 06:56 PM
If you look at current temps, then add 1/3 or so, that would be closer to what I would think it would be like. Not accurate at all, but a ballpark estimate.
  #29 (permalink)
Old November 23, 2009, 07:07 PM
Current temps are under 80C for both GPUs at a fan speed low enough to be mostly inaudible. Temperatures could be easily controlled with a more power-hungry card simply by spinning up the fan a bit.
  #30 (permalink)
Old November 23, 2009, 07:17 PM
I'm not saying 5970's with higher clocks won't happen, I'm just saying I doubt a 5990 will ever exist unless Fermi is spectacularly good.
[FS] AMD Phenom II X4 955, ATI Radeon 4850 512MB, ATI Radeon 4870 1GB icarus2 Buy/Sell & Trade 9 November 12, 2009 03:19 PM
Will Not Post. Farmrush Troubleshooting 24 September 4, 2009 12:24 AM
[FS] ATI 4850, ATI Theatre 650, XMS2 Ram FrankyG Buy/Sell & Trade 7 August 2, 2009 12:22 PM
No POST miggs78 Troubleshooting 8 August 21, 2008 06:40 PM
ati 3870x2 VS ati 4870 triumph Video Cards 2 July 26, 2008 05:21 PM
