Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
  #21 (permalink)
Old September 30, 2009, 09:14 PM
IRQ Conflict's Avatar
No HDMI on a ~700 dollar card? Adapters suck!
-Rampage- Motherboard: Asus Rampage Formula CPU: Q6600 @ 3.2Ghz Cooling: OCZ Vendetta 2 Ram: 4GB OCZ Reaper HPC PC2-8500 5-5-5-15 @ 540Mhz Video Card: Sapphire Radeon HD 5870 @ 850/1200 Storage: Seagate Barracuda 4x 500GB Barracuda 7200.11 Raid 0 Power Supply: PC P&C Silencer 750 Quad Case: Antec P180B Monitor: Syncmaster 245T OS: Vista 64bit
  #22 (permalink)
Old October 1, 2009, 07:02 PM
ToXic's Avatar
ew.... 12 inch card... yea... im going Nvidia haha
Some kind of pathetic Apple convert
17" Macbook Pro (early 2011 model)
2.2Ghz i7-2720QM | 8GB Corsair DDR3 1333Mhz | 750gb Toshiba HDD | ATI 6750M 1GB
  #23 (permalink)
Old October 1, 2009, 07:23 PM
Sushi Warrior's Avatar
5870X2 won't work at 5870 stock clocks, unless they want a 380watt TDP....
You're half way through some post and you realize it's from some retard who types like he's got an array of dog dicks for fingers
  #24 (permalink)
Old October 1, 2009, 07:35 PM
Cowboy's Avatar
Where do you get that number? Can you back it up?
I've personally seen a 5870x2 running @ 5870 clocks... and a 5870 has the tdp close to the gts 250 according to some reviews. Your forgetting we're dealing with 40nm tech here.
  #25 (permalink)
Old October 1, 2009, 07:56 PM
Linus's Avatar
actually adapters are not a problem at all for DVI to HDMI. They are pin compatible. There is no signal degradation WHATSOEVER.
Please note: I am not here to provide official NCIX support on these forums.
For faster (and official) NCIX service please contact our customer care team at www.NCIX.com (Canada) or www.NCIXUS.com (USA)
Heatware: http://heatware.com/eval.php?id=25647
  #26 (permalink)
Old October 2, 2009, 05:50 AM
gingerbee's Avatar
@linus can you use dvi to vga adapters with 1 displayport monitor for eyefinity
  #27 (permalink)
Old October 2, 2009, 11:31 AM
ToXic's Avatar
the 12 inch length bothers me... i mean i gotta big case and i doubt this big bastard will fit... looks ugly to like some sorta devil brick, all it needs to do is shoot fire and smoke and open portals to hell periodically to let the undead army through. At any rate... im not willing to put 700$ down on something like this... but ill put 800$ on a GTX3xx aha...
  #28 (permalink)
Old October 2, 2009, 01:38 PM
O man...I wish I had the money for a 5870X2...
DREWL!
  #29 (permalink)
Old October 2, 2009, 02:08 PM
"Quote This..."
Originally Posted by Cowboy View Post
Last night, my friend and I went to go see "this guy" ( I will not mention his name) about purchasing a few video cards. I had heard that "this guy" had access to unreleased and OEM ATi cards. Turns out he brought with him a 5870x2, a 5850x2, 1 vanilla 5870, and 1 5870 Black edition (which I purchased). He would have brought 2 5870x2's (my friend was looking to buy both), but something went wrong with the second one and "this guy" thought it was defective, so he brought just 1.
Anyways, after talking to "this guy" for a bit, and taking a LOT of pictures with my phone, I bought the 5870 Black edition and my friend went home with nothing because he wanted 2 5870x2's and "this guy" promised that he would find a second one within a week or two. At that time, my friend and I will be benchmarking the crap out of those 2 cards to see what they can do. I'll be posting the results on HWC.
I don't exactly know what is so special about the card I bought, it was the same price as the other one. I can only assume it is different for one reason "it clocks better". I'll see about that once I get working on it.
Details about the 5870x2:
-No idea on clocks still, "this guy" didn't say. I would assume they would be stock 5870 clocks
- The card is 12" long or longer. I could not measure it with anything, but it was significantly longer than the 5870.
- The card uses 1x 6 pin and 1x 8 pin power headers
- It is a 2gb card
- It performs similarly to 2 4870x2's in Quadfire
- The stock cooler is similar in design to the 5870, just looks more "badass".
- No idea on temps, or fan speed/ noise levels since I didn't see it in action
- 2 slot design
- 2 DVI outputs and 1 unknown connector (I am guessing its a "mini display-port" for Eyefinity)
Details on the 5850x2:
-No idea on clocks, however I assume that 5850 stock clocks will be applied
- Card is the same length as the 5870x2
- Card uses the same power connectors as the 5870x2
- No idea on memory capacity
- No idea on performance
- The stock cooler is much different from the 5870 and 5870x2.
- uses two "dualorb" style coolers to cool each of the the gpu's directly and independant of the other
- fan's draw power from solder points on the PCB of the card
- Fans intake air from inside of case and dump heat back in to the case.
- No heatsinks on the memory to cool it down
- 2 slot design
- 2 DVI outputs and 1 unknown connector that is identical to the one found on the 5870x2
Details on the 5870 Black edition:
- same as 5870 vanilla in appearance, save for the replacement of the red accents with black plastic, and it has a glossy black finish as opposed to the more matte black/gray of the "vanilla" version.
-The fan is still red
-There are no ATi logo's on the side of the card, only on the fan is there a sticker that has the ATi logo on it.
PICS COMING SOON!
Fixed.
ASRock Z68, 8gb DDR31866mhz, 2600k @ 4.4ghz, GTX 590 Hydrocopper, 3 - 60gb Vertex SD's in Raid 0. Watercooled in a 650D
  #30 (permalink)
Old October 3, 2009, 12:11 AM
DREWL!
i thought you retired lol
maximus IV extreme @ 5.1 1.41v +gtx580 + HeatkiLLer H0le waterblock
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
5870x2 Pictured Bojamijams Rumor Mill 9 October 2, 2009 01:38 PM
Where is the 5870x2 Mark Video Cards 4 September 23, 2009 07:22 PM
specs 5870/5870x2 ati hightest Video Cards 10 May 1, 2009 08:13 PM
Imminent Hot Deal...Now CONFIRMED cadaveca Computer & Electronics Hot Deals 48 March 18, 2009 08:27 PM
Abit exits mainboard market - confirmed yamawho Rumor Mill 14 August 29, 2008 10:11 AM
