Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
  #81 (permalink)
Old September 23, 2009, 06:01 PM
belgolas's Avatar
Originally Posted by Killswitch View Post
Yeah, 16:10's are starting to fade away it seems. I had my rig tied on to a friends 30" Dell a little while ago and oooooooooo man it was sweet. I had FC2 and Wolfenstien running all out at 2560x1600 pretty smoothly. So a 27" running 1920x1200 would be perfect IMO. There's a small problem with that though. It's not in my budget right now, and won't be for a while.
Why would you get a 27" monitor when it will look no better than a 24" monitor with just a significant price jump? 16:9 is also more widescreen than 16:10. There are some great prices for great monitors. You can get a 23.5" monitor that is 1080P for under 200. That is a great deal. I almost regret buying my 30" monitor for it's price and that I could have gotten a few 24" monitors for less and used ATI's new eyefinity. I still love the picture quality but I could have got more for less.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
  #82 (permalink)
Old September 23, 2009, 06:23 PM
That's... odd logic. It's less screen and can fit inside 16:10. The extra area is better for day-to-day use and gaming.
  #83 (permalink)
Old September 24, 2009, 02:08 PM
Thats not really true. a 22" 16:9 monitor is not just a 22" 16:10 monitor with the top and bottom hacked off a bit. Both are measured angle to angle, which means a 16:9 will be slightly wider than a 16:10 of the same screen size.
Case: HAF 932
CPU: AMD Phenom II 940 3.5ghz w/ OCZ Vendetta 2 Cooler
PSU: OCZ StealthXstream 600w
Mobo: ASUS M3A79-T Deluxe
Memory: 4gb OCZ Platinum 1000mhz ddr2
Graphics: 2x Sapphire 4830s in Crossfire
Keyboard: Logitech G11
Mouse: Logitech G9
HD:WD 640gb Caviar Black + 750gb Seagate
#hardwarecanucks on irc.enterthegame.com
Tags
rumor
