Go Back   Hardware Canucks > NEWS & REVIEWS > Rumor Mill
  #31 (permalink)
Old July 9, 2009, 01:33 PM
DrPepper's Avatar
But isn't things that come in the future smaller? Like the 4770 is already 40nm, and the 5870 should be smaller.
  #32 (permalink)
Old July 29, 2009, 09:47 PM
elwoodz's Avatar
hopefully it will come out soon, been waiting to upgrade
  #33 (permalink)
Old August 23, 2009, 10:18 PM
Kylzer's Avatar
Specs via wiki say
  • 750-900 MHz core clock speed
  • 1GB of GDDR5 running at 1100 MHz (effectively 4400 MHz)
  • 1200-1600 shader processors (compared with 800 on the current HD 4870)
  • 32 ROPS (compared with 16 on the HD 4870)
  • 60-80 TMUs (compared with 40 on the HD 4870)
  • 2.1 TFlops of effective computational potential (around double the TFlops offered by the HD 4870)
  • over 300 mm˛ DIE (~256 mm˛ RV770/790)
  • DirectX 11 Support
Only time will tell though.
  #34 (permalink)
Old August 24, 2009, 09:26 AM
The annoncement will be made on Sept 10th in New York and card will be shipped on Sept 24th so we'll get them by end of september/ start of october. Also benchmark result will have a NDA until Sept 24th.
That info come from the latest rumours, aparts from the sept 10th date witch is real...
  #35 (permalink)
Old August 24, 2009, 10:19 AM
gingerbee's Avatar
all tell you the specs when they come out or we can all keep guessing ha ha
  #36 (permalink)
Old August 24, 2009, 05:41 PM
jcmaz's Avatar
More Deatils Come Forth on The ATI Radeon HD 5870 and 5850 Video Cards - Legit Reviews
-Plato
  #37 (permalink)
Old August 24, 2009, 08:30 PM
gingerbee's Avatar
now that looks promising thank
  #38 (permalink)
Old August 24, 2009, 08:37 PM
Realityshift's Avatar
Bah this tells me nothing >.<
The Builders Hammer
  #39 (permalink)
Old August 26, 2009, 01:07 PM
ToXic's Avatar
im bothered i just got a 4870 x2... better start savin my pennys to buy a 5870 x2... or maybe a GTX 300 hah
Some kind of pathetic Apple convert
17" Macbook Pro (early 2011 model)
2.2Ghz i7-2720QM | 8GB Corsair DDR3 1333Mhz | 750gb Toshiba HDD | ATI 6750M 1GB
  #40 (permalink)
Old August 26, 2009, 01:49 PM
artistpavel's Avatar
GTX 300 is rumored for Q1 10 release, are they gonna just sit and watch how ATI dominates next gen market for half a year?
Tags
rumor
