Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old April 18, 2007, 06:19 PM
Babrbarossa's Avatar
Super Moderator
Default Nifty Planon Docupen reviewed by TechGage
This is a NEAT gadget! You could get your self in and out of all kinds of trouble with this thing if you were imaginative enough. It does color and is literally not much bigger than a pen. (ok if I use your pic, Rob?)
"While the fact this scans colour is very nice, most of the practical uses of this pen do not necessarily require colour, such as receipts, documents, books, business cards, blueprints, etc. That being said, it was definitely a bonus to be able to scan the photograph and retain the colour information. It is definitely an improvement over previous portal scanning products both by DocuPen and its competitors, so if you're going to get a scanner pen, this is the best one you're going to find, and the only one I found with expandable memory.
It has many more resolution and colour depth options than anything else comparable, it is very, very easy to use and the documents are simple to manipulate. It is, as far as I know, the only document scanner that is not held like a pen. Whereas most alternatives are held pen-like and only scan a few lines at a time, this DocuPen is unique in its ability to scan an entire page in seconds. It's ten times the scanner at less than twice the price of the closest competition."
More from TechGage
Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830
Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump
HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180
Old April 18, 2007, 11:15 PM
Shadowed's Avatar
Thats a cool little device. I don't know about the 8mb memory though. Last time I was messing around with a scanner, I ended up with a 100mb file... oops..
OCZ Cryo-Z reviewed! Wankerfx Reviews & Articles from the Web 14 March 13, 2008 07:15 AM
3850 AGP reviewed-yes, AGP Babrbarossa Reviews & Articles from the Web 8 February 19, 2008 02:51 PM
105 PSUs reviewed! Babrbarossa Reviews & Articles from the Web 9 April 30, 2007 06:19 AM
OCZ SLI pc 7200 memory reviewed by TechGage Babrbarossa Reviews & Articles from the Web 2 April 2, 2007 03:11 PM
Thermaltake Soprano DX reviewed by TechGage Babrbarossa Reviews & Articles from the Web 2 March 13, 2007 09:22 AM
