Go Back   Hardware Canucks > NEWS & REVIEWS > Reviews & Articles from the Web
Old April 16, 2007, 08:52 AM
Babrbarossa's Avatar
Default Cooler Master iTower 930 review by TechGage
Not exactly a case geared toward the extreme gamer, the CoolerMaster iTower 930 (why does everything need an "i" in front of it these days??) is perfect for the desktop user who stores mucho media, and wants to be able to swap HDs often. They give it an 8/10
"With everything installed, the Cooler Master iTower 930 provided us a great chassis for a home server or simple everyday use PC. For anyone who is considering this case for the foundation for a gaming PC, I would strongly advise them to look elsewhere. While this is an incredibly well built case, the airflow isn’t exactly ideal. It does provide just enough to keep your hard drives in check, if you add in a set of hot running video cards, your internal temps can really start to heat up.
As a server, this case is top notch and because of this, it earns an 8 out of 10. The 930 is robust, well built and provides a safe and secure chassis for all of your most important data. One thing I would like to see on future models though is the ability to lock the front of the case. While you can lock the side panel to keep your internals safe and secure, the front is fair game for anyone that can operate a hot swap drive. Not a huge problem but for those who are paranoid, this will most certainly deter them in their choice.
  • Pros
  • Well built and sturdy
  • 4 bay hot swap
  • Front access to drives
  • Tool less design
  • Makes for a stylish and convenient data center case
  • Cons
  • Air flow could be better
  • Front could use a lock"
More from TechGage
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
Cooler Master Mystique 632 Case Review Beermaster Member Reviews 9 May 6, 2007 08:10 PM
Cooler Master GeminII Review by X-Bit Labs Babrbarossa Reviews & Articles from the Web 0 April 5, 2007 10:31 AM
Another peculiar GPU cooler from Cooler Master: CoolViva Pro Review by X-Bit Babrbarossa Reviews & Articles from the Web 7 March 19, 2007 05:19 AM
Cooler Master iTower 930 Case Review @ MTB Supergrover Reviews & Articles from the Web 3 December 31, 2006 11:35 AM
