A Canadian reviewer on a German site reviewing a Taiwanese Case- Check this one time..Here are their pros and cons:
(They list the price as about 150 USD)
- "Superb quality
Strong
Looks
Layout and adjustable HDD rack
No sharp edges
Light weight
Large amount of space for a midtower
Quiet - Three 120mm fans
- Takes finger prints and are hard to get rid of
Finish can scratch fairly easily
<No 3.5" drive bays - Power&Reset switch/HDD&Power LED cable too short
9.8To put it simply; I love the Lian Li PC-A16. At first I questioned its size, but that turn out not to be a problem. The simplicity of the case to me is fabulous, but to others, it might be too "plain jane". The quality of the case is very good; in quality of the materials, the build, and design. The case is quiet in operation due to the large 120mm fans and all the rubber dampeners used in the case. Like all things however, it does have some issues. The biggest one I found was that you can't use the top 5.25" drive bay due to the Power&Reset switch/HDD&Power LED cable being too short. I thought maybe it was just a issue with the case I received, but I did a little reading and found other users with the same issue. Some other little things I mentioned were that the case finish takes finger prints and scratches easily. Well that's to almost be expected with the finish the PC-A16 has. There also aren't any 3.5" bays. That's not a huge thing these days, but some people (like me) still like to use a floppy, or have some 3.5" bay accessories. Besides those minor things, the case is very well made, and I am certainly pleased with it." More from TechPowerUp
Main: ASUS P6TD Deluxe// i7 920// XFX HD 7970// 6GB GSkill Trident 2000// Corsair HX1000// Temjin TJ-07// OCZ Vertex2 240GB// GSkill Titan 256 SSD//Kingston SDnow 120GB// Logitech G9 //X-Fi Prelude//Merc Stealth//
Cooling: Coolit Boreas 12 MTEC// HK copper v.3//EK multi 150 res// Swiftech mcp355//EK nickel WB
Screen: Samsung 27" 850D
