Legion revisits ddr2 performance: a look at latency using the 680i They tested gaming performance using different latency memory kits on a 680i chipset anda Core 2 Duo. While this conclusion does not extend to AMD chipsets, they found that with C2D tighter timings did not make a significant performance improvement over cas5 or cas6. 1:1 ratios also did not offer any advantage. Recommendation: save your money. "Recently I published an article titled “DDR2 Memory Frequency Performance” which looked at the value of high speed memory. The reason I found the need to write such an article was to demonstrate that there really is no need to try and overclock your memory when pushing a Core 2 Duo processor to the max. Often readers complain about poor Core 2 Duo overclocking performance and 99% of the time it comes down to memory instability at higher frequencies. This article showed that when running a Core 2 Duo E6700 on a 500MHz FSB, DDR2-667 was just as fast as DDR2-1181 memory and in some cases even faster." More from Legion
__________________ Building: ASUS P6T X58// i7 920 // SLI evga 260GTX 216SC// 3X2GB Patriot Viper DDR3-1600// Antec TP Quattro 850w // CM Stacker 830 Water Cooling: Apogee GTZ// 2X evga HC16 GPU block// HW Labs Black Ice GTX Xtreme 360 // Swiftech MCR220 // Swiftech mcp655 pump HTPC: Asus Commando // e6400 @ 3.4 // Crucial Ballistix PC2 8000 // evga 260GTX 216SC// LG super opti-blue HD optical drive// DVB clone PCI satellite receiver//OCZ GXStream 700w // ACFP7 CPU cooler // Antec p180 |
